bags Posted November 2, 2016 Report Share Posted November 2, 2016 I have a 99 vln 610 w/ the above transmission. When I try for reverse the R and N light flashes back and forth. Trans goes in and out of reverse but never engages for more than seconds. The first time I had this problem I was hooking up and able to crawfish it under the rig and hook up. I drove 300 miles, and and the problem cleared up. I spoke w/the Volvo service rep and he said chances of the code still being there were slim and it was probably an electrical problem that resolved itself. The problem returned. I drove another 300 mile and still no reverse. This morning I disconnected the neg battery cable and will let it sit 1 hour or so. My question is, if this battery disconnect clears what ever is, will this be a temporary fix or do I still need to get it to the dlr. I had the reverse switch replaced 20k miles ago along with the bearing. That time however the trans R light would just flash and the trans would never engage. this time the R & N flash back and forth. Thanks JB John and Michal Bagley 1999 Volvo 610 the 'Millennium Falcon', 400 hp ISM, Autoshift Gen 2, single axel w/steel bed, Pressure Pro, VMSPC, Trailer Saver Air Hitch, 3 bags, 38 foot Royals International, and our 3 dogs. Link to comment Share on other sites More sharing options...
SIBERNUT Posted November 2, 2016 Report Share Posted November 2, 2016 Just wait- when you get in the middle of a road & try to shift too fast F & R, it may do it too. Give it a few minutes shut off, usually will find itself. Try cycle ign key 3 times before start. If these don't work, yer just gonna' have to sacrifice the chicken on the hood. 2000 Volvo 635 A/S, N-14 Cummins"The Phoenix"'03 KA 38KSWB http://s918.photobucket.com/user/sibernut/library/?sort=6&page=1Furkids- Sibe's CH. Sedona & Tseika Link to comment Share on other sites More sharing options...
bags Posted November 2, 2016 Author Report Share Posted November 2, 2016 Rooster or hen? thanks JB John and Michal Bagley 1999 Volvo 610 the 'Millennium Falcon', 400 hp ISM, Autoshift Gen 2, single axel w/steel bed, Pressure Pro, VMSPC, Trailer Saver Air Hitch, 3 bags, 38 foot Royals International, and our 3 dogs. Link to comment Share on other sites More sharing options...
Dollytrolley Posted November 2, 2016 Report Share Posted November 2, 2016 Rooster or hen? thanks JB Both Drive on..........(Don't drive up a dead-end ally till ya get Reverse ......back) 97 Freightshaker Century Cummins M11-370 / 1350 /10 spd / 3:08 /tandem/ 20ft Garage/ 30 ft Curtis Dune toybox with a removable horse-haul-module to transport Dolly-The-Painthorse to horse camps and trail heads all over the Western U S Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted November 2, 2016 Report Share Posted November 2, 2016 Maybe this will help? http://www.wellertruck.com/pdf/tsupp/ElecTS/Eaton%20Gen%201%20Autoshift%20Troubleshooting%20Guide.pdf Link to comment Share on other sites More sharing options...
billr Posted November 2, 2016 Report Share Posted November 2, 2016 Same issue same tranny as yours. Mine was Reverse ball sw. I replaced it cost was $30 from Volvo. Removed one tested bad with ohm meter on removal. Code and T/S called up switch. I see you relplaced one maybe same switch? There is another one just like it diff part number though for rev lights. Bill and Joan and 3 Collie pups 2001 Volvo VNL 770 "The Doghouse" Singled short, "ET" hItch VED12 465HP Gen 1 Autoshift 3.58 ratio 2005 Mobile Suite 38RL3 2011 Smart Passion loaded piggybacK Weigh-It Portable RV Scales http://www.weighitrv.com/ Link to comment Share on other sites More sharing options...
HERO Maker Posted November 2, 2016 Report Share Posted November 2, 2016 Great info guys!! Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
