Smitty77_7 Posted October 24, 2016 Report Share Posted October 24, 2016 We're in the process of debugging a problem with satellite dish connections. (Found one cable connection that had signs of corrosion, after about 18 months.) I've cleaned all roof connections RG6 Coax's, and also protected with anti corrosion protection spray. But, they're still up on the roof (Winegard Trav'ler related, Winegard RAZR Auto related, Winegard Sensar IV related.), subject to advert weather and driving at 50-65MPH in rain conditions. So, reaching out for tips and best practices on waterproofing! Some of my thoughts, of which some could be wrong, are: -Use could RG6 cable, and coax components. (All of mind, except OEM ends of Winegard, are of higher end quality.) -Clean with electronic cleaner, per directions. -Apply anti corrosion protection, before connecting. Then it gets to where I am now. Add extra levels of protection, such as the following options, and I suppose that is my question, which of these, or others, would be a good move? (In no particular order!) -Heat shrink wrap connections -Plastic Spray Tape connections -Put on sanitizing gloves, and spread silicon seal around all connections points -Move to a climate with zero moisture!!! Or, with exception of the last (Not a go for the DW!), combo's of each... ------ How about it. What is it some of you veterans do to protect of the long haul - external (And internal!) electrical connections such as: Coax; Speaker Cables; RCA Jacked HiFi and or HDMI cables, etc. TIA, and best for all, Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
Pat & Pete Posted October 24, 2016 Report Share Posted October 24, 2016 Go to Home Depot and buy : Nashua Tape 1 in. x 3.33 yd. Stretch and Seal Self-Fusing Silicone Tape in Black (116) Write a Review Questions & Answers (14) Peel-back design for easy handling Protects against rust and corrosion Creates a permanent, watertight seal $6.98 /each Goes around , comes around . Link to comment Share on other sites More sharing options...
Ed ke6bnl Posted October 24, 2016 Report Share Posted October 24, 2016 I was going to recommend the same thing, self adhering silicone tape, I used good 3m electrical tape years ago this was not known to me or not available for ham radio antennae connections. But I would maybe use dielectric silicone grease on fitting before making up the connections then the silicone tape. My satellite went out last week while on vacation and I thought it was the connections, come to find out that there was such a thick layer of cloud cover that had affected the reception along with the 48 hr. straight of rain in the Sierras. 2000 National RV Sea Breeze 5th wheel 30ft. So.California 1950 F1 street rod 1949 F1 stock V8 flathead 1948 F6 350 chevy/rest stock, no dump bed shortened frame. 1953 chevy 3100 AD for 85 S10 frame 1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc 1970 Baha Bug wihg 2332cc, King coil overs and everything else there is. 1998.5 Dodge 2500 4x4 Cummins, turbo, trans, injectors, lockers, bigger turbo,edge EZ upgrades for towing 35" BFG's, air dog lift pump etc. Link to comment Share on other sites More sharing options...
cpaulsen Posted October 24, 2016 Report Share Posted October 24, 2016 I just use dielectric grease on my coax connections and do not have any problems. Link to comment Share on other sites More sharing options...
Pat & Pete Posted October 24, 2016 Report Share Posted October 24, 2016 Careful with Dielectric grease . It is electrically insulating . NON - conductive . Some has silica . It is good for helping insulate a connection when a rubber 'boot' is used , as in conjunction with a spark plug boot . But , do not use it in a direct connection . Goes around , comes around . Link to comment Share on other sites More sharing options...
Bobi and Dick McKee Posted October 24, 2016 Report Share Posted October 24, 2016 For years as sailboaters we protected our electronics with Boeshield. Sprayed our connections and never had a problem. Dick . http://boeshield.com Link to comment Share on other sites More sharing options...
Smitty77_7 Posted October 24, 2016 Author Report Share Posted October 24, 2016 Thanks for all of the tips. I had seen the self fusing silicone tape before. Have numerous cans of Boeshield T-9, but of course, they're in my garage at home:)! Looked for some at both Lower and Home Depot in Oregon, and they did not carry it. Bought a similar CRC product, that I used after cleaning all of the connections with Electronic Cleaner. Will look for the silicone tape, and probably redo all of the connections next month when we get home. Best to all, Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
Smitty77_7 Posted October 24, 2016 Author Report Share Posted October 24, 2016 Had to chuckle at myself (I find that more and more often, I'm able to relieve stress by laughing at something I have done:)!), went to True Value (The big hardware store within a 30 mile range of where we're staying.) No T-9, and that is OK. No self sealing silicone tape. Or at least it seemed. They said to wait and ask Nick, as he was on the phone with a customer. And nick thought about it, and said Rescue Tape. I was walked over to the Rescue Tape, and reading the package - IT IS SELF SEALING SILICONE TAPE... And the part that made me chuckle, was that I have a roll in my tool box, for 'just in case!' moments. Never knew it was self sealing silicone tape:)! So, bought another roll, and will use this when I get home and have the Bioshield T-9 available... Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
Kirk W Posted October 25, 2016 Report Share Posted October 25, 2016 On the silicone tape, I have looked at it, but never used any. How is it to remove if that is needed? Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ray,IN Posted October 25, 2016 Report Share Posted October 25, 2016 On the silicone tape, I have looked at it, but never used any. How is it to remove if that is needed? A sharp knife and delicate touch when slitting it will remove it, it fuses together when stretched and overlapped. If you have a leaking radiator hose, you can apply the tape per directions and it will seal the leak until you reach civilization again. Never tried it on an electrical connection.http://www.rescuetape.com/ 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
mscans Posted November 10, 2016 Report Share Posted November 10, 2016 We're in the process of debugging a problem with satellite dish connections. (Found one cable connection that had signs of corrosion, after about 18 months.) I've cleaned all roof connections RG6 Coax's, and also protected with anti corrosion protection spray. But, they're still up on the roof (Winegard Trav'ler related, Winegard RAZR Auto related, Winegard Sensar IV related.), subject to advert weather and driving at 50-65MPH in rain conditions. So, reaching out for tips and best practices on waterproofing! Some of my thoughts, of which some could be wrong, are: -Use could RG6 cable, and coax components. (All of mind, except OEM ends of Winegard, are of higher end quality.) -Clean with electronic cleaner, per directions. -Apply anti corrosion protection, before connecting. Then it gets to where I am now. Add extra levels of protection, such as the following options, and I suppose that is my question, which of these, or others, would be a good move? (In no particular order!) -Heat shrink wrap connections -Plastic Spray Tape connections -Put on sanitizing gloves, and spread silicon seal around all connections points -Move to a climate with zero moisture!!! Or, with exception of the last (Not a go for the DW!), combo's of each... ------ How about it. What is it some of you veterans do to protect of the long haul - external (And internal!) electrical connections such as: Coax; Speaker Cables; RCA Jacked HiFi and or HDMI cables, etc. TIA, and best for all, Smitty I have used very successfully, a product from Caig Labs called De-Oxit https://www.amazon.com/s/?ie=UTF8&keywords=cramolin&tag=mh0b-20&index=aps&hvadid=3080931934&hvqmt=e&hvbmt=be&hvdev=c&ref=pd_sl_9kl752rl3a_e Works well and I have used it for years. Recommended it to George of Tioga George and he swears by it also. Happy Trails, Florida Mike EXPERTS AREN'T!! Link to comment Share on other sites More sharing options...
