GlennWest Posted May 13, 2016 Report Share Posted May 13, 2016 To those of you that have done this, any precautions I need to make. Pull ECU fuse, pull ecm fuse? 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted May 14, 2016 Author Report Share Posted May 14, 2016 Well, I changed it. Removed ecm fuse. Still have abs light. This module was for a single rear axle. 4s/4m and had all the features of my original module. Likely have to let Freightliner look at it. Hopefully some changes need to be in computer. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
MrSeas Posted May 14, 2016 Report Share Posted May 14, 2016 Glenn did you drive the truck or just run it? Sometimes an "ABS" fault will clear when you get up to a certain wheel speed. The code may go inactive after a number of key cycles. Link to comment Share on other sites More sharing options...
GlennWest Posted May 14, 2016 Author Report Share Posted May 14, 2016 No didn't drive it. Hope you are right. Will drive it some morrow. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
CDR Posted May 14, 2016 Report Share Posted May 14, 2016 Glenn, Glenn, Glenn.... Â If the trucks been sitting for a while you may get an ABS light until you drive a mile or so, then brake. Or if you start up (without moving) usually rests after keying on/off. It's typically dirt by the sensor or locked drums. Â But you would have figured this out with "Access Freightliner", with which gives you your operating manual. As well.... Â Curt 2001 Freightliner Century, 500hp Series 60, Gen 2 autoshift, 3.42 singled rear locker. 2004 Keystone Sprinter 299RLS (TT) 2 & 4 Wheelers! 2013 Polaris Ranger 800 midsize LE Our motto "4 wheels move the body, 2 wheels move the soul!" Link to comment Share on other sites More sharing options...
Scrap Posted May 14, 2016 Report Share Posted May 14, 2016 Got my fingers crossed for ya! Do you guys have an ABS test switch to get codes with? I think some FL's had them behind the drivers seat? Or by the diagnostic plug? Link to comment Share on other sites More sharing options...
GlennWest Posted May 14, 2016 Author Report Share Posted May 14, 2016 Hadn't found my operating manual. The one listed is for new trucks. Few of the switches look like mine. I haven't found the data plug yet. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
CDR Posted May 14, 2016 Report Share Posted May 14, 2016 Scrap; Â Most Century/Columbia/Coronado's will have a plug just behind the drivers door threshold (door step plate). It is either on the trim panel or under an oval cover plate there. Â Glenn; Â When/If you get into Access Freightliner you will have the manuals for "Your" truck. Not a generic version. Â Curt 2001 Freightliner Century, 500hp Series 60, Gen 2 autoshift, 3.42 singled rear locker. 2004 Keystone Sprinter 299RLS (TT) 2 & 4 Wheelers! 2013 Polaris Ranger 800 midsize LE Our motto "4 wheels move the body, 2 wheels move the soul!" Link to comment Share on other sites More sharing options...
GlennWest Posted May 15, 2016 Author Report Share Posted May 15, 2016 I searched on there today. Didn't find mine. Found new models dpf, etc 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted May 17, 2016 Author Report Share Posted May 17, 2016 update, Drove truck 60ish miles yesterday. Abs light on whole way. Bummer. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
HERO Maker Posted May 17, 2016 Report Share Posted May 17, 2016 Sounds like when the axle was dropped, no re-programing of the computer took place. If it is necessary on a FL? Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry  Link to comment Share on other sites More sharing options...
GlennWest Posted May 17, 2016 Author Report Share Posted May 17, 2016 Good question. And no it has not been reprogrammed by Freightliner. Going there in near future. Want to get info and clear governor while there. Reading about pulling a relay and resetting abs. Going to do more research. Do believe I will remove all the extra cables, etc left over from the removed axle. May find one plugged in wrong. so much all together now hard to isolate. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted May 31, 2016 Author Report Share Posted May 31, 2016 Fixed. Cables were wrong. Cleaned up, removed all used abs cables. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
