TripKitty Posted March 25, 2016 Report Share Posted March 25, 2016 So, I am actually moved into my rv and have spent the last week living in it. I'm still parked in the driveway of my house while transitioning. (And I'm thankful for that too at the moment). Yesterday, I discovered my water pump had a slight leak. I pulled the old one out and am planning to replace it rather than try to repair it since it's 25 years old by the date on it. Since I'm not close to an RV store, I'm ordering a new one off amazon and going back to using my house for things where I need running water for a few days. Are there any tips on things I can do when installing the new one to make it quieter? The area currently has carpet in it, but I plan to tear it out since it's 30 years old at this point and very gross. I am thinking to line the area with some rubber... I used some rubber door mats to line a storage compartment and thought I'd cut a piece for this area. Is there any reason why screwing the water pump down on top of the rubber mat would be a bad idea? Looking closely at the area, I think it may have been leaking for some time, but it would have been hard to notice since the carpet would have soaked up a lot of the water. I'm also thinking the rubber mat would make any future leaks more noticeable and easier to clean up. I've never replaced a water pump before. Any other tips that may be useful? Thanks in advance for the help! Class B, 1984 Dodge Xplorer van by Frank Industries. Follow my life and travels at my blog, Live Hoppy. Link to comment Share on other sites More sharing options...
Yarome Posted March 25, 2016 Report Share Posted March 25, 2016 Is there any reason why screwing the water pump down on top of the rubber mat would be a bad idea? Any other tips that may be useful? Nope. Sounds like a good idea to me. You might want to secure your hoses. Leave the pump end a little slack in case you need to remove the hose connections, but basically you're trying to prevent the hoses from slapping around if you're pump has a tendency to "pulse". Link to comment Share on other sites More sharing options...
oldjohnt Posted March 25, 2016 Report Share Posted March 25, 2016 Trip, I have replaced several, and like you try to limit their noise, here are my thoughts FWIW not one thin dime but hey you asked. To deaden noise I've used few pieces of that acoustic sound absorbing egg crate foam "stuff" to line the compartment walls, THAT REALLY HELPS. As far as a rubber mat to mount on, all well and good, but "real hard" rubber doesn't help all that much, sure it does some. Carpet on the floor is a good sound absorber Some have those soft rubber grommets where the mounting screws go through, just don't screw them down so tight you loose the benefit of the shock absorbing soft rubber. I WOULD NOT BE WITHOUT one of those small captive air bladder tanks (like a shock absorber for air and pressure) that reduces short cycling and too much pump switch cycling that happens at low flow conditions. When the faucets are barely cracked it saves your pressure switch from chatter and overworking. In line filter on the suction inlet side??????????/, Ive had and not had them but its prob a good idea to keep foreign material out. Its good if you have fairly heavy gauge wire from the source to the pump, like at least 12 or even 10 versus 14 or 16. Fused and protected of course. This may be controversial and not exactly same as my friend Yarome, but IFFFFFFFFFFFF you have the space available you might consider a hose loop where the flexible hose lines attach to the pump to allow for contraction and expansion and flexibility as the pump could (depends on mounting) torque just a tad when starting and I have even placed that thin foam insulation over the lines which protects them and reduces noise BUT AS YAROME WARNS YOU DONT WHAT THOSE LINES SO LOOSE WHERE THEY JUMP AROUND!!!!!!!! Often there no room to do all of the above and sure it will work as long as hooked up and no leaks John T NOT a plumber or RV technician so do as the experts say over me. Link to comment Share on other sites More sharing options...
Randyretired Posted March 25, 2016 Report Share Posted March 25, 2016 A flexible loop on the outlet as others have described worked well for us. An accumulator tank also helps. Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
TripKitty Posted March 25, 2016 Author Report Share Posted March 25, 2016 Thank you all for the tips. I WOULD NOT BE WITHOUT one of those small captive air bladder tanks (like a shock absorber for air and pressure) that reduces short cycling and too much pump switch cycling that happens at low flow conditions. When the faucets are barely cracked it saves your pressure switch from chatter and overworking. Is this like what you mean? http://www.amazon.com/SHURflo-182-200-Pre-Pressurized-Accumulator-Tank/dp/B000N9VF6Q/ref=sr_1_12?ie=UTF8&qid=1458927014&sr=8-12&keywords=rv+water+pump Class B, 1984 Dodge Xplorer van by Frank Industries. Follow my life and travels at my blog, Live Hoppy. Link to comment Share on other sites More sharing options...
skp51443 Posted March 25, 2016 Report Share Posted March 25, 2016 TripKitty, We used a small one like that right on the outlet of the pump on all our rigs. It did reduce pump noise a good bit and reduced cycling some so it was well worth installing. When we got a bigger rig with more room we still added the small one at the pump but also added a much larger one in the basement, the big one did nothing for noise but it really cut down on cycling. 2 gallon: http://www.amazon.com/WaterWorker-HT-2B-Pressure-2-Gallon-Capacity/dp/B001AZL562/ref=sr_1_2?ie=UTF8&qid=1458928284&sr=8-2&keywords=accumulator+tank+rv 3 gallon: http://www.amazon.com/Everpure-EV310275-3--Gallon-Accumulator-Tank/dp/B009GENHZ6/ref=sr_1_8?ie=UTF8&qid=1458928284&sr=8-8&keywords=accumulator+tank+rv First rule of computer consulting: Sell a customer a Linux computer and you'll eat for a day. Sell a customer a Windows computer and you'll eat for a lifetime. Link to comment Share on other sites More sharing options...
oscarvan Posted March 25, 2016 Report Share Posted March 25, 2016 The song of the water pump is part of the RV'ing sound scape to me....... Previously a 2017 Forest River, Berkshire 38A, "The Dragonship". https://dragonship.blog/ Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted March 25, 2016 Report Share Posted March 25, 2016 You can also use a variable speed pump that will run just enough for the required flow and not have the bladder. I went that way due to reduced time spent changing it out and not much room to add the 2 gallon bladder I was going to use. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
hemsteadc Posted March 25, 2016 Report Share Posted March 25, 2016 A flexible loop on the outlet as others have described worked well for us. An accumulator tank also helps. x2. The flexible outlet hose should cure 90% of the noise. Link to comment Share on other sites More sharing options...
oldjohnt Posted March 25, 2016 Report Share Posted March 25, 2016 Trip, yep a small one similar to what you linked works well for me http://www.amazon.co...s=rv water pump mines a different brand but similar in size However my buddy has a much larger one probably like what Stanely posted and if you want to spend more money go the variable speed route LOTS OF PRICES AND OPTIONS OUT THERE. You want a Chevy or a Cadillac lol to each their own John T Still NOT a plumber so no warranty lol Link to comment Share on other sites More sharing options...
Kirk W Posted March 25, 2016 Report Share Posted March 25, 2016 x2. The flexible outlet hose should cure 90% of the noise. My experience as well. Lining the space with sound insulation don't quite the pump it prevents the sound from getting out. But the pump is connected to a semi-rigid water line made of pex (typically) and that pipe transmits the vibrations from the pump and acts exactly like the sound board of a piano or acoustic guitar. If you install a flexible line between the pump and the rigid line on each side of the pump, it solves most of the problem. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
oldjohnt Posted March 26, 2016 Report Share Posted March 26, 2016 I have to agree with Kirk and old,, I prefer flexible hose sections to the pump versus the fairly rigid PEX or Gray tube like they used to use. If you use hose and flex loops to allow for expansion/vibration, plus the rubber pump mounts maybe carpet and even the egg crate foam insulation I mentioned earlier, you're going to achieve much much quieter operation. But if too quiet you may never hear that tell tale now and then pump cycling which happens when you have a very small leak lol a guy just cant win Keep your water flowing gang............... John T Link to comment Share on other sites More sharing options...
TripKitty Posted March 26, 2016 Author Report Share Posted March 26, 2016 OK, I have the parts on order from Amazon- a new pump, some flexible hoses & the small tank from the link I posted before. Being a van, I have no space for a larger tank and am not sure I can get the small one to fit, but I'm going to give it my best shot. I think I have some of that egg crate foam so I'll use that. I don't really need the pump to be totally silent- since I'm traveling solo, it's not like I'm trying to sleep through it or anything. But it did used to make quite a bit of a racket, so if I could get it to be 50% quieter or so, that would be nice. Now, I just have to wait for the parts... the last one won't be here until Wednesday... the sweet feeling of anticipation. Class B, 1984 Dodge Xplorer van by Frank Industries. Follow my life and travels at my blog, Live Hoppy. Link to comment Share on other sites More sharing options...
