alan0043 Posted February 23, 2016 Report Share Posted February 23, 2016 Hi Everyone, I am replacing the front shock's on a '98 VNL 420 or a gen 1 truck. My question is. Does the tubing or spacer that goes thru the top and bottom of the shock get pressed out ? I have seen pictures of replacement shocks without the tube. I have also seen a picture with a shock that has the tube on top and bottom. This shock is a different part number then the first shock that I was talking about. The Volvo part # on my truck is 8078195. It crosses over to Monroe # 65494. This Monroe shock has no tubing or spacer in any pictures that I have seen. Some how I came across another Monroe shock with part # 65130. This shock was pictured with the spacer. Now for the confusion, which part # to use. For the people that replaced their front shocks on a gen 1 truck what part # did you use ? Who gave you the best deal ? Has anybody used the Stengel Bros. for parts ? Thank you for any help, Al Link to comment Share on other sites More sharing options...
Nuke-E Posted February 23, 2016 Report Share Posted February 23, 2016 Al, I think RandyA used Stengel for his shocks. There should definitely be a metal sleeve running through the rubber bushing. I'd be surprised if you ended up getting shocks without it already there. Link to comment Share on other sites More sharing options...
bmzero Posted February 23, 2016 Report Share Posted February 23, 2016 Al, I think RandyA used Stengel for his shocks. There should definitely be a metal sleeve running through the rubber bushing. I'd be surprised if you ended up getting shocks without it already there. I agree. Knowing website product photos and data the way I do, my suspicion would be that they're using the same photo for multiple shocks. I bet all of the correct shocks for your truck will have the spacer in them even if the photos online do not show that. I purchased the first set of shocks on my truck from a local TruckPro. I was able to compare to the old shocks I took off to make sure they were right before I bought them. Link to comment Share on other sites More sharing options...
On The Road Posted February 24, 2016 Report Share Posted February 24, 2016 I just received the Monroe 65494, they do have the spacer. Have not got them installed but they look the same as the shocks that are on the truck now. I have been spraying with half transmission fluid and half acetone hoping that will help with the removal. They were 62.88 on Prime which is free two shipping. Also easy to return if they were wrong. About the best price I found. Link to comment Share on other sites More sharing options...
alan0043 Posted February 24, 2016 Author Report Share Posted February 24, 2016 Hi Guys, Thanks for the info. Of the four bolts that hold the shocks, I have three out. It always figures there is always one bolts that will cause all kinds of problems. It is the bottom bolt on the drivers side. The impact gun has not been any help or a large hammer. It looks like the touches come out to play. It think the problem is that the bolt is rusted to the spacer. The nut on the back side is also off. I won't be able to work on the truck till the weekend because of the weather. Right now the bolt has been sprayed with PB blaster on both ends. I can remember the pain in the @ss the rear shocks were. Al Link to comment Share on other sites More sharing options...
Nuke-E Posted February 24, 2016 Report Share Posted February 24, 2016 Al, You're not the first to run into that. Mine were easy, but I know of several here that have not been able to get the bolts out with non-destructive means. Thinking out loud--I wonder if dielectric grease on the bolt going back in would help prevent the moisture-causing rust in there? I'm sure none in this crowd will probably need to replace shocks a second time, but I can't see how it would hurt. The same shock (Monroe 65494) went on my truck (even though I have a 14,600lb front axle). I also bought from Amazon (link here: http://amzn.to/1LFWvnX ), and you'll notice in the picture that the spacer is included. Link to comment Share on other sites More sharing options...
bmzero Posted February 24, 2016 Report Share Posted February 24, 2016 Rather than use a dielectric grease you would be farther ahead to use some never seize. I have taken bolts apart that have had some never seize on them that were used outside at a refinery and they came right out after being in place for over 15 years. I caught a case of the Never Seize once. It's highly contagious. You'll be wiping it off of everything within a 5 mile radius for days, but Mntom is right. That's what you should use when going back together with the shock bolts. Loctite now makes it in a stick that is a little cleaner to use than the brush, but not by much. http://www.amazon.com/Loctite-37616-Copper-Anti-Seize-20-gram/dp/B0029SZIUI http://www.amazon.com/Loctite-37617-Silver-Grade-Anti-Seize-20-gram/dp/B0053ZS1Z8/ref=pd_bxgy_263_img_3?ie=UTF8&refRID=1PMAMEQATNY4V1P9M55Z Link to comment Share on other sites More sharing options...
alan0043 Posted February 26, 2016 Author Report Share Posted February 26, 2016 Hi Everyone, I have some answers for my own questions. Maybe someone had the same questions as me. My shocks arrived yesterday. I just ordered them on Wednesday from the Stengel Bros. They had the best price at the time. The spacer is part of the new shocks. The part # 65494 replaces the old part # 65130. These numbers are for Monroe shocks. Now I need the weather to co-operate. One more bolt to come out. I think this is going to be a job for the gas wrench. Thank Everyone for your help, Al Link to comment Share on other sites More sharing options...
On The Road Posted February 28, 2016 Report Share Posted February 28, 2016 Replaced the front shocks today with the Monroe 65494. All went well and did not have to use the fire wrench. Had sprayed several times with the mixture of acetone and auto transmission fluid, mixed half and half. Those yellow rascals sure are pretty. Especially after they are installed. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted February 28, 2016 Report Share Posted February 28, 2016 Al, How did you decide your shocks needed replacing? On a car used to just push a fender down, let it go and see how many oscillations occurred. How do you tell on a semi? Link to comment Share on other sites More sharing options...
MrSeas Posted February 28, 2016 Report Share Posted February 28, 2016 I just changed mine last year, don't know how long they had been on there. The old ones were worn out. I could compress them very easily and they had no rebound at all. I guess you could always take one off and check the rebound yourself. Another thing to add to the ECR "project" list! The Monroe part number for my 2005 780 front shock was a 65497. Scott Link to comment Share on other sites More sharing options...
SuiteSuccess Posted February 28, 2016 Report Share Posted February 28, 2016 I just changed mine last year, don't know how long they had been on there. The old ones were worn out. I could compress them very easily and they had no rebound at all. I guess you could always take one off and check the rebound yourself. Another thing to add to the ECR "project" list! The Monroe part number for my 2005 780 front shock was a 65497. Scott Thanks Scott. Bet my 2006 780 would be same part number. Did have them checked when I had my kingpin bushings replaced few years ago and they said were ok but small shop and pretty busy so got the impression they really didn't want to mess with them. Link to comment Share on other sites More sharing options...
On The Road Posted February 28, 2016 Report Share Posted February 28, 2016 The ones I removed were also easy to compress and no return. They were Sachs brand. Looking forward to see they make a difference in the driving Link to comment Share on other sites More sharing options...
alan0043 Posted February 29, 2016 Author Report Share Posted February 29, 2016 Hi Everyone, Some how my reply never got posted. I made a reply to Carl some time around 9:00am this morning. The reply is not there. I will try to remember what I said at a later date. I had a note that there was a server problem on my end at that time. Anyone else ever have a server problem ? The problem lasted for about 8 hours on my end. Al Link to comment Share on other sites More sharing options...
Phil D Posted February 29, 2016 Report Share Posted February 29, 2016 Yes, the server was down for much of the day, making the Forums unavailable. You must have been posting when it crashed. For some reason, the database seems to like to crash on the weekends. Link to comment Share on other sites More sharing options...
Bob Cochran Posted February 29, 2016 Report Share Posted February 29, 2016 Glad you got that bolt loose using Acetone and Transmission fluid. The only thing I have found better but more expensive is a product called KROIL. Usually not available locally like PB or WD40 have to order it. I think most on here know about all this stuff but thought would pass on. Link to comment Share on other sites More sharing options...
alan0043 Posted February 29, 2016 Author Report Share Posted February 29, 2016 Al, How did you decide your shocks needed replacing? On a car used to just push a fender down, let it go and see how many oscillations occurred. How do you tell on a semi? Hi Carl, I'll see if I can try this again. You asked me how I know the front shocks were bad. It started at the back of the truck. I looked at the rear shocks and the top bushings had pieces missing out of them. So I decided to replace the rear shocks. That is a story for the camp fire. lol. I also replaced the rear air bags at the time. I had a feeling the rear shocks were original to the truck because the shocks had red paint on them. The frame of the truck was painted red when it was built. I thought if I replaced the rear shocks why not replace the front shocks. The front shocks also had red paint on them. That was a clue that they were original to the truck. I got the last bolt out with the help of the gas wrench. I had just enough gas to get the job done. The front shocks have no rebound to them at all. Al Link to comment Share on other sites More sharing options...
Nuke-E Posted February 29, 2016 Report Share Posted February 29, 2016 Carl, In my case I was able to see that they were a Volvo shock, and made the assumption that probably meant they were original. These things aren't much different than the shock on a car--100K miles or so and they're probably due. But what I'd do is just take out one bolt on one of them and see how easy it is to move by hand. You can just open the hood to get to them--no need to take a wheel off or anything. It would be easy enough to compare to another truck with new shocks at the ECR if you weren't sure. I can say it was money extremely well spent--the change in ride quality (even though the old shocks only had 220K miles on them) was significant. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted February 29, 2016 Report Share Posted February 29, 2016 Thanks Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 1, 2016 Report Share Posted March 1, 2016 Here is the "shock rule". Get a new-to-you truck: New front and rear shocks and new cab shocks. You won't regret it. Link to comment Share on other sites More sharing options...
