Curiosity Question - Not RV related - Truck Axles
gg923
This is not really a RV Hauler question but rather one of curiosity that I think this group can answer.
We have spent the last couple of months in WA and have noticed that most of the commercial T/T combos have a LOT of axles. Being from FL & TX the typical config is a single or tandem tractor with a trailer with tandem axles. The tractors up here in WA have 3, 4 and 5 REAR axles and then the trailers have 4, 5 and 6 axles (or may not actually be axles but have support "drop down type" Tire wheels in front of the rear axles) but most have at least 4 real axles.
I have difficulty believing that they are hauling loads that are that much heavier (maybe they are) - can any of you "in the know" educate me? Bet the tire business is good!
thanks!
Gene & Lisa (and Abby)
2014 Chevy 3500 D/A 4x4 Dually
2015 DRV Mobile Suites 38PS3
Trailersaver TS3
2012 Toyota Prius
There are weight limits on the force of an axle on the pavement. More axles allow a greater load capacity and stay within the limits of the force on the pavement.
There is a rather complicated calculation of axle loading called the bridge formula. Here is an example: a single axles can be up to 20,000 lbs. But it an additional axle is close enough to the first axle (about the spacing of a tandem) the combined load of the two axles is only 38,000 lbs.
Mark & Dale
www.dmbruss.com
When I was living in Kalispell, MT, I noticed the same thing. In Montana, every Spring, The ground under the roadbed would start to thaw and become almost liquid. The roads would actually open up and start to fall apart because of the liquidation of the earth. The trucks would put down their drop axles to keep from doing as much damage to the roads by distributing the load over more area/tires. I believe that some trucks also had more axles that did the trucks where I grew up, the Portland, OR area.
Trish & Raquel
"Road Runner" -- 2005 Volvo VNL780, 500hp Cummins ISX, Ultra-Shift, ET-Hitch, 198" wb
"Wile E." -- 2013 Heartland Landmark San Antonio
In the Midwest these regulations are commonly referred to as Bridge Laws
Raquel and Mark gave very good explanations!
Rick and Alana
Fulltimers
2018 Newmar Ventana 4037
2020 Jeep Gladiator
1997 Jeep TJ
2009 Mobile Suites 36RSSB3
formerly owned 2000 Volvo 770, 600 Cummins ISX,18 speed autoshift, 14 foot "garage"
ET,Jackalopee,MaxBrake,Pressure Pro pro
www.rickandalanasgreatadventures.blogspot.com
If you're in Michigan look out for what they call a Michigan Millipede. Those units are axles pretty much from one end to the other!
George,
Suzuki Celerio 998cc
Yamaha NMAX scooter
Work ride is Western Star N2 Tri-Tri tanker at 56,500kg loaded
Thanks! Great Info! Had not really thought about the road bed situation being so different but that makes a lot of sense.
Trailersaver TS3
2012 Toyota Prius
Most of the weight laws are based on a pounds per inch of tire width, here in Michigan it ii something like 154000# on10 axles plus the steer tires before you have to get special permits. Lots of Mi. trains, 3 axle tractor with 2 3 axle trailers and a dolly being one of the most common configurations. the next most common is a single trailer with 8 axles, with 3 of them having lift capability so they can be drug around a corner
Michigan also has a thing they do in the winter where they shut certain roads down due to temperature. You are not allowed to move your equipment (cranes, dozers, etc) over those roads regardless of wheels and axles. At $38,000 a month rent plus fines per day, and with the roads shut down for over a month, you don't miss many opportunities to move your equipment out.!!
2013 Smart Passion
2012 CanAm Spyder RT
It comes from this: https://en.wikipedia.org/wiki/Federal_Bridge_Gross_Weight_Formula
Aside from the classic "20k for single axle, 34k for tandem, steer tires limited by tread width", there's also a complex equation based on axle spacing as shown in the link above. I haven't done the math, but I suspect it's the reason the dump truck + dump trailers often have long, extendable "tongues". I suspect they extend to maximum overall length when loaded, and shorten up for easier manuevering when empty.
Notice that the formula has to be rerun for every possible set of axles: not just axles 1-5, but also 2-5, etc. Apparently 1-3, 1-5, and 2-5 are the typical ranges that truckers exceed, so those are likely the ones they calculate.
