Alie&Jim's Carrilite Posted July 18, 2015 Report Share Posted July 18, 2015 As the title says, what is your preference? I have had both on different trailers, different set-ups, different purposes. Some folks are having issue with the current run of IS suspensions with the covers breaking and letting grease fly out. I also know that MorRyde and Dexter both had issues with leaking oil seals. I also have had issue with the NeverLube, had to replace 1 bearing unit after 20k of miles. Is one actually any better than the other? Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
SuiteSuccess Posted July 18, 2015 Report Share Posted July 18, 2015 Jim, Funny you post this. Just for grins, couple of months ago, I researched pros and cons of NeverLubes, EZlubes, regular bearings, oil bath, disk vs. drum brakes etc. on the internet. Opinions were everywhere and pretty evenly divided. Apparently the Neverlubes had some problems couple of years ago especially the Timken Chinese manufactured replacements. That seems to have been corrected, but "seems" is a big word. My personal preference is the NeverLubes since it is one less yearly chore repacking bearings and I do the Dexter check yearly. I would prefer disk brakes on my trailer but have drums. If properly maintained and adjusted don't know which is better. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
CrazyCooter Posted July 19, 2015 Report Share Posted July 19, 2015 If I had my choice, I would spec Neverlubes too since I despise packing wheel bearings. I would have a spare hub bearing or two on hand since it seems like not everyone got up to speed and stocks them. Maybe even just an idler hub with a bearing pressed in so you could continue on your way in the case you were on the side of the road with a warm bearing after a quick roadside check. That said, I have been thinking of swapping the current rig over to oilbath next service. Next best thing since we already have the packable bearings on the current rig. Beware NAPA really sticks it to you for the 7/8K oil bath wheel seal.....like $50 ea. The trailer suppliers are half the price and the seal is actually the same Chinese manufacturer! Surprise there..... 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted July 19, 2015 Report Share Posted July 19, 2015 9 years on our Nev-R-Lube bearings. We stop at MOR/ryde every once in a while for a checkup (look for axial play). Only issue I ever heard of was Nev-R-Lubes in offset hub wheel on light trailers. The manufactures like the offset to get more space between the wheels. The Nev-R-Lubes bearing are for 0 offset wheels. Those Nev-R-Lube bearings are the same kind used in railroad axles. Talk about a long useful, non-maintenance life. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted July 19, 2015 Report Share Posted July 19, 2015 I prefer greased bearings and just do the yearly maintenance on them while cleaning and lubing the brake caliper slides, I usually check everything during our annual maintenance including shocks, tires, light lenses, etc. I don't like Nev-R-Lube bearings for two reasons, they can'r be inspected to see if a bearing surface is starting to gall and they are impossible to put in sitting on the side of the road. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
CrazyCooter Posted July 19, 2015 Report Share Posted July 19, 2015 I have not packed my bearings in at least 3 years. I figure I did it so I know they were clean, adjusted properly, I used an Amsoil synthetic grease, and have self adjusting brakes. At the RV dealer, how do you know if the grease they used was compatible with what was last used? Not everyone cleans everything out in a jet washer or solvent tank....... Before every major trip, about twice a year, I jack up each wheel, check for play, and spin the wheel to listen for roughness. I can also see the brake linings from the rear. Having oil in the hub gives you another possible indicator that something isn't right if it's discolored or has metal in it. 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
oletimer Posted July 19, 2015 Report Share Posted July 19, 2015 The oil bath is very easy, and I think if you are on the road a lot, they work great, but if your trailer sets around the seals seem to leak. I have some farm trailers that leak often, but they might set for several months at a time. I have the packable bearings on my trailer, but I never wash them. I have a bearing packer that, using a grease gun, pushes the old grease out, while packing the new grease in. Never had a bearing failure, but came close with my resent axel upgrade because of brake pad heat, and China bearings. That happened at about 16K miles. Hard to find good USA bearings. I watch the front wheel bearings on the Volvo close, as they are oil bath. Dick T 2006 Volvo VNL 630(VED12 400HP)10 speed autoshift,3.58 gear 236" twin screw, w/ET, Jackalopee, Blue Dot2016 Space Craft 37' Blu/Dot, Dexter 8K triple axel, HD Drum hydraulic brakes Feather lite air ride2005 Jeep Rubicon2007 Suzuki DR 650 Link to comment Share on other sites More sharing options...
Jack Mayer Posted July 19, 2015 Report Share Posted July 19, 2015 I have Never-lube. I've had all the others, including oil bath. I prefer the NL.....never had any issue and the issues in the past with the NL were resolved pretty fast. Like Mark, we let MorRyde inspect them when we go through.... Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
