TwoBearBill Posted May 28, 2015 Report Share Posted May 28, 2015 Up until now, my truck has never leaked onto the pavement. But I noticed oil seeping out of the side of the steering gearbox. Looks like it's coming from under a round cover about 4" in diameter held on by a big "e-clip". Something I can do myself? My initial search of the forums found advice to replace and not attempt to repair. Bill Greenwade Full Timer from Mena, Arkansas 2012 KZ 40ft 5th Wheel Toy Hauler 1998 Volvo VNL 610 Link to comment Share on other sites More sharing options...
Ronbo Posted May 29, 2015 Report Share Posted May 29, 2015 No. The gearbox has to come off. About 100 lbs. special puller to remove arm from shaft. Check http://www.straightlinesteering.com for prices. They were very fast to ship. I paid local shop to remove and install Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
billr Posted May 29, 2015 Report Share Posted May 29, 2015 If its the original box it is likely getting sloppy and time to change out anyway. It goes over time and steering gets gradually loose until its bad enough to notice the wander thing...ha On a Volvo, The arm that has to be pulled off as Ron mentioned is mounted against the frame rail and makes using a standard puller not possible. I ended up having a shop replace mine as well. I was happy and they were not! ha Took them 2 hrs to get that arm off. They don't do a lot of Volvo stuff and said most trucks have that arm mounted opposite faceing out in the open. Bill and Joan and 3 Collie pups 2001 Volvo VNL 770 "The Doghouse" Singled short, "ET" hItch VED12 465HP Gen 1 Autoshift 3.58 ratio 2005 Mobile Suite 38RL3 2011 Smart Passion loaded piggybacK Weigh-It Portable RV Scales http://www.weighitrv.com/ Link to comment Share on other sites More sharing options...
SIBERNUT Posted May 29, 2015 Report Share Posted May 29, 2015 A small amount of steering slop can be adjusted out. The flat screw inside the nut can be tightened. Loosen nut, screw in & re-tighten nut. 2000 Volvo 635 A/S, N-14 Cummins"The Phoenix"'03 KA 38KSWB http://s918.photobucket.com/user/sibernut/library/?sort=6&page=1Furkids- Sibe's CH. Sedona & Tseika Link to comment Share on other sites More sharing options...
Ronbo Posted May 29, 2015 Report Share Posted May 29, 2015 I paid flat $300 for the change out. Gearbox was $500 exchange. They paid shipping both ways. Ken worth did not list a rebuilt for my truck and new was $2500 Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
TwoBearBill Posted May 29, 2015 Author Report Share Posted May 29, 2015 Good to know - thanks! Bill Greenwade Full Timer from Mena, Arkansas 2012 KZ 40ft 5th Wheel Toy Hauler 1998 Volvo VNL 610 Link to comment Share on other sites More sharing options...
Chad Heiser Posted May 30, 2015 Report Share Posted May 30, 2015 I had the seals replaced in mine at the dealer about two years ago because it was leaking. It stopped the leaks pretty well until a few months ago. It started leaking badly again recently so I decided to replace the steering box completely at my annual service this month. It is in the shop right now being done. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
