Grassy
Storage space on a MDT ?
We are moving into long timers and  planning fairly long hauls.
The DW was wondering if anyone has built or buy a storage system for all that wasted space on the back of our trucks.
I don't think a totter box would work...
Any help is appreciated..
Ian
Share this post
Link to post
Other than a 5th hitch, nada.
The toolbox is interesting but want something a lot larger than maybe runs from cab to the hitch.
This is a really bad pic of the truck when I got it ..looks quite different now..
As long as I was under or away from the sweep of the 5th, I think I am ok..  but we don't want to block off the rear windows..
Share this post
Link to post
Hi Glenn,
The truck is in storage at the moment .. but I would think there is 6 foot between hitch and cab.
Is there something off the shell or do I need to fabricate one ?
I hate to resort to tupperware boxes :)
Share this post
Link to post
I ordered my boxes from American Trucklboxes. They are heavy duty and built to my size. Mine are 30" deep, 26' tall. Have 2 60" long. One 28" long. Many build their own but I don't have a shop to work at. We full-time.
Edited by GlennWest
Share this post
Link to post
Be careful about putting boxes on the bed.  You need a minimum of 55" of clearance forward of the 5th wheel hitch jaws, and preferably 60" just to be safe.  This is calculated based on the widest possible 5th wheel trailer (102") divided by 2 (102/2=51).  Then add a few inches for clearance (51+4=55).  You need this clearance to allow for the trailer to go to 90 degrees to the truck when turning/backing.
Measure the back of your cab to the 5th wheel hitch jaws (center point of the hitch) then subtract a minimum of 55" from that measurement.  This is the widest box you can put up against the back of the cab on the bed of the truck.  You also said you do not want to block the view from the rear window of your truck.  This means the tallest your box can be is from the floor of the bed to the bottom of the window.  With these two limiting measurements, you will quickly discover the largest box you can have on the bed of your truck.
Edited by Chad Heiser
Share this post
Link to post
oh oh....  and crud.
My 5th doesn't overhang the hitch. If the boxes were of lower height than the top of the pin box,  I still could be in a position while backing up where contact  could be made with the trailer.
Glad I asked and when the snow starts to go away, I shall be measuring.
Thanks all.
Share this post
Link to post
Google Stalick Conversion(no longer in business) and  Mountain Master in Phoenix(I assume they are still in business).  We had  Stalick and loved all the storage plus we had our bikes on the toolbox in the bed.
I don't think we had any 55" of space in front of the hitch. The most you wouldd need would be about half your trailer width.
Share this post
Link to post
51" is half a wide body 5er (102").  The extra 4 inches to get to 55 is for clearance when turning on uneven ground.  You don't want your truck/trailer leaning into the other on an up hill/downhill turn.
Share this post
Link to post
We ended up installing a ProTech aluminum box on the back of ours.  We purchased the 24" X 24" X 72"  (20-2614DR) box with double doors.  Mounted right behind the cab and has ample storage for our needs.  Absolutely love it.
Double Swing Diamond Doors, Passgr. Side 72"
Share this post
Link to post
My old International had a Highway Products bed that included a center storage area behind the cab that was probably 40"x30"x18" deep as well as shallow storage (6") over the wheel wells that had gull wing lids.  TONS of storage.  Have a look at https://www.highwayproducts.com/highwayman-rv-hauler-tow-body for some ideas.
Tried to upload a photo of my old rig but system would not take it.
Lenp
Share this post
Link to post
Hi Glenn,
What material are your boxes made of ? Steel or aluminum ?
Al
Share this post
Link to post
1 hour ago, alan0043 said:
Hi Glenn,
Al
Mine are steel. They sell both. Weight is a plus on my truck.
Share this post
Link to post
If you are looking for something inexpensive, consider 2 or 3 drawer lateral files behind the cab.    They are not water tight but they are pretty well covered.      Most lateral files are about 40" wide and 18-19" deep, two side by side would likely fit perfectly on your bed.
Steve
Share this post
Link to post
Grassy,
I was not suggesting you buy a new bed, just trying to give you some ideas.  They are expensive - I think they are around $26K today.
Lenp
Share this post
Link to post
11 hours ago, lenp said:
Grassy,
Lenp
Len,
I appreciated the link.
I thought about it...they look good.  We do have a metal fabricator locally ( he builds firetrucks / ambulances)  ..  he is booked a year in advance I think..  I talked to him a couple of years ago when I thought I could convert a mdt myself.
What we now have above in this thread  are ideas that my DW and I can thrash around which is move than we have when I asked the question.
Thanks, Ian.
Share this post
Link to post
Have you looked at the ones designed for your rig and offered by Sportchassis?  We have them on our 2015 and we have a ton of storage.  There is one on each side of the bed and a massive one on the rear of the cab.
http://www.sportchassis.com/options/exterior/saddle-bag-storage-unit
http://www.sportchassis.com/options/exterior/bolt-on-storage-unit-treadplate
Share this post
Link to post
There is a lot of wasted space on the back...tapping into it like the honda truck did is interesting...but would have to be very waterproof..
Interesting.  Thanks !
Share this post
Link to post
Shade My RV
