bmzero Posted August 12, 2015 Report Share Posted August 12, 2015 First trip out since the rally tomorrow! 200 miles round trip and it will be nice to not tow a trailer at snail's pace! Looking forward to the new ride with the loads on the rear to smooth things out. Now, that's what I'm talking about!!! I will probably side load a RZRS 1000, which is 106". I could probably get it down to 102" with some transport-only tires/wheels if it becomes an issue. Quote "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
Broncohauler Posted August 12, 2015 Report Share Posted August 12, 2015 (edited) Watch where you put side marker lights on your bed. I think you can see mine ? 2 inch flush mount. They're right in the way of where I want to put my ramps. So the chrome rings I have around them keep getting broken. I never planned on sideloading anything when I built the bed. But I did make removable side rails for loading pallets with the forklift. They slide the same as side rails on a rollback tow truck and are held with pins. Also watch your hitch Height. Stock my rhino just cleared the fifth wheel hitch loading from the back. But with the long travel suspension it's wider and lower and just skims over the top of the fifth wheel plate. The razor and I think CAN- AM are going to be longer so you really need to be careful. As for the side lights if I did it again I would still use 2 inch LED but French them into the bed sides. Edited August 12, 2015 by broncohauler Quote Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 13, 2015 Author Report Share Posted August 13, 2015 Published spec on the RZR 1k is 119"? They are a tad longer than my Maverick in stock form. I got a bumper that tucked in tighter so I didn't have to pull it off every time to load it in the hauler. I'd never try to side load mine for a trip....I'd have a problem for sure! Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 13, 2015 Author Report Share Posted August 13, 2015 Watch where you put side marker lights on your bed. I think you can see mine ? 2 inch flush mount. They're right in the way of where I want to put my ramps. So the chrome rings I have around them keep getting broken. I never planned on sideloading anything when I built the bed. But I did make removable side rails for loading pallets with the forklift. They slide the same as side rails on a rollback tow truck and are held with pins. Also watch your hitch Height. Stock my rhino just cleared the fifth wheel hitch loading from the back. But with the long travel suspension it's wider and lower and just skims over the top of the fifth wheel plate. The razor and I think CAN- AM are going to be longer so you really need to be careful. As for the side lights if I did it again I would still use 2 inch LED but French them into the bed sides. I can see where the lights could be an issue. I dont think the hitch will be a problem though. 30" tires on the SXS and 35's on the Jeep. Guess we'll see when the ramps get here! Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 13, 2015 Author Report Share Posted August 13, 2015 I have plate type to side load rhino. Just make sure you use a tie down 1/2 way up to keep them from spitting out. Home made steel for bronco. They fit in small cross over box at the bottom of the bed. I love your setup! Both trucks are sooooo clean! Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
VegasFlyer Posted August 13, 2015 Report Share Posted August 13, 2015 Ended up getting some ramps from a seller on Ebay. They were slightly longer that the ones from Discount Ramp, in stock, and $300+ less. Should do the job? http://www.ebay.com/itm/171823591537 I was on the fence which ends to get.....figured a didn't need full knife and couldn't really decide hook or plate on the other. Figured these would be most universal. Nice ramps that you found. What is the deck height of your truck? Quote John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 13, 2015 Author Report Share Posted August 13, 2015 (edited) With air bags dumped the dove tail height is 43" with 51" deck height. I measured the angle at over 40° with the 60" ramps I was using. Edited August 13, 2015 by CrazyCooter Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
Broncohauler Posted August 13, 2015 Report Share Posted August 13, 2015 I love your setup! Both trucks are sooooo clean!Thank you I appreciate it. Quote Link to comment Share on other sites More sharing options...
bmzero Posted August 13, 2015 Report Share Posted August 13, 2015 Published spec on the RZR 1k is 119"? They are a tad longer than my Maverick in stock form. I got a bumper that tucked in tighter so I didn't have to pull it off every time to load it in the hauler. I'd never try to side load mine for a trip....I'd have a problem for sure! The RZRS 1000 is the new model released a couple of weeks ago, built off the new RZR platform released last year. The RZR XP 1000 definitely would not side load. http://www.polaris.com/en-us/rzr-side-by-side/rzr-s-1000-eps-white-lightning Quote "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 13, 2015 Author Report Share Posted August 13, 2015 The RZRS 1000 is the new model released a couple of weeks ago, built off the new RZR platform released last year. The RZR XP 1000 definitely would not side load. http://www.polaris.com/en-us/rzr-side-by-side/rzr-s-1000-eps-white-lightning That little 1000S is cool! I had a RZR 800S back in the day and always thought if they made something with more travel and HP, it would be a blast! That Ace 900 could be fun too! Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 18, 2015 Author Report Share Posted August 18, 2015 (edited) Got the ramps today and had to try them out..... [/url] Harbor freight rates the straps at 1,000lb....4 of these should be fine.....NOT Tight squeeze! That grab bar might have to come off...... Edited September 8, 2015 by CrazyCooter Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 18, 2015 Author Report Share Posted August 18, 2015 Not much room here.....Might not work. Hitch bag at proper height. Bag dumped....at least the arc swings away from the Jeep. Top Thinking it's time to calibrate the scales. I was thinking I had it close, but that won't fly! Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
bmzero Posted August 18, 2015 Report Share Posted August 18, 2015 Wow. That's a full load. Are you going to have enough turning/articulation clearance? Ramps look great. Quote "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
bmzero Posted August 18, 2015 Report Share Posted August 18, 2015 Some small OD transporation-only wheels/tires would probably buy you some extra clearance. Quote "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 18, 2015 Author Report Share Posted August 18, 2015 (edited) I'm not sure how much I can tweak things to work there. If I pull that grab bar, I can get 2-3", pull the front axle down with straps to the axle should gain me 2-3" without really stressing things..... My buddy suggested sinking the tires into the deck for a few inches in the past. Swapping tires is more work that I want to deal with as the whole theme of my camping is not to work on vacation. Have to play with this a little more as I'm not sure how the front cap articulates being in front of the pivot with the different movements. That Ti front cap that was a cool feature for a pickup is now biting me in the rear! Edited August 18, 2015 by CrazyCooter Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
dzlnut Posted August 18, 2015 Report Share Posted August 18, 2015 I would recommend getting some heavier duty straps that have chain ends http://www.truckntow.com/cargo-control/ratchet-strap-components/2-winch-straps-w-chain-anchors.html with ratchets that have chain ends as well http://www.truckntow.com/cargo-control/ratchet-strap-components/vulcan-proseries-ratchet-short-end-with-chain-anchor.html also you should run the straps around your jeep's axles in a criss cross pattern, thats a much better securement point Quote Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 18, 2015 Author Report Share Posted August 18, 2015 (edited) I got one set of these: http://www.uscargocontrol.com/Towing-Auto-Hauling/Wheel-Nets-Auto-Car-Tie-Downs/2X8-Short-Wide-Ratchet-Strap-W-Axle-Strap-10-000Lbs .....and a set of these except with snap hook ends:http://www.uscargocontrol.com/Towing-Auto-Hauling/Wheel-Nets-Auto-Car-Tie-Downs/Side-Mount-Wheel-Net-W-Ratchet-and-Flat-Hook Those cheasy straps were what I used to hold the ramp from spitting out. I just put them on there as a little joke for you guys! I have always cross tied to the axles with chains/binders but decided to try the ratchet straps since they are lighter, quieter, and don't rust. I might even weld on d rings to the axles to make it even easier! I'm getting lazy and our goal has been no more than a 20 min setup/teardown.... This is vacation. Edited August 18, 2015 by CrazyCooter Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
GoldRush Posted August 18, 2015 Report Share Posted August 18, 2015 One steep driveway and its over! Quote Link to comment Share on other sites More sharing options...
AZStang Posted August 18, 2015 Report Share Posted August 18, 2015 Just let the air out of the fronts on the Jeep. Looks like it would drop 6". Could do that with the rear too and leave the bar on the back of the sleeper. Quote Link to comment Share on other sites More sharing options...
GoldRush Posted August 18, 2015 Report Share Posted August 18, 2015 How about a full profile shot that shows the whole bed, cab, jeep and trailer nose? You can cut the jeep out of the pic and articulate it on the rest of the photo and see what mod can gain you the most clearance. Quote Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 18, 2015 Author Report Share Posted August 18, 2015 I'll have to play with it when I have more time and the straps get here. I just had to pit it up there and see. BoonHauler and I were having a laugh last night when I told him how close I thought it was going to be.....he told me to leave the hood open! Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
HERO Maker Posted August 18, 2015 Report Share Posted August 18, 2015 I'm wondering in reality how many degrees of a turn it will take until you start "customizing" the corners of your trailer? I'm thinking maybe 30 until you have contact??? Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 18, 2015 Author Report Share Posted August 18, 2015 My problem isn't turning as much as it being close. The nose will pivot away. It just too close especially since the Flexair hitch anti-chucks too. Gonna take some more tuning before I give up. Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
VegasFlyer Posted August 18, 2015 Report Share Posted August 18, 2015 Did you have any flexing in the bottom of the ramps, when you were loading? It looks like your deck height is higher than the design height of the ramps, though your ramps look stouter than 3,000 pound ramps. Quote John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 18, 2015 Author Report Share Posted August 18, 2015 I didn't notice any flex in the ramps at all. The seller rated these at 5,000lb per pair and claimed half knife ends were stronger for when you used then at a steeper than ideal angle. Time will tell I guess. I do know I didn't pucker one bit loading or unloading. The width and length are about right. Quote 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
