Cotreker Posted October 31, 2023 Report Share Posted October 31, 2023 Where on the intake manifold do I find the place to tap into the vacuum for boost gauge? Where does the Pryor probe need to be installed. Does it need to welded with bung? What brands are favorites? Where to purchase? Lastly where on dash are you mounting gauges? Thanks, if this topic is already posted could not find. Quote Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Steve from SoCal Posted October 31, 2023 Report Share Posted October 31, 2023 I don't have a Volvo but, I did install a pyro and boost gauge in my truck. "Most" engines have a plug on the elbow at the head for a boost gauge. The exhaust housing on the turbo should have a plug as well? The thermocouple should be on the cold side of the turbo to prevent damage if the probe fails. If either of the locations have to be pierced a tap should be all that is needed to install the sensor. Drilling the exhaust housing after the turbine is not an issue. Drilling the intake elbow should be done with the elbow open and a rag beyond the area to keep swarf from entering the engine. Don't know the Volvo dash but, the gauges should be in an area within the normal scan of instruments. I found getting the sensor wires/tubing into the cab the most daunting part of the job. The most direct path may not be the best or even pracitical way in to the cab. Quote 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted November 1, 2023 Report Share Posted November 1, 2023 8 hours ago, Steve from SoCal said: I don't have a Volvo but, I did install a pyro and boost gauge in my truck. "Most" engines have a plug on the elbow at the head for a boost gauge. The exhaust housing on the turbo should have a plug as well? The thermocouple should be on the cold side of the turbo to prevent damage if the probe fails. If either of the locations have to be pierced a tap should be all that is needed to install the sensor. Drilling the exhaust housing after the turbine is not an issue. Drilling the intake elbow should be done with the elbow open and a rag beyond the area to keep swarf from entering the engine. Don't know the Volvo dash but, the gauges should be in an area within the normal scan of instruments. I found getting the sensor wires/tubing into the cab the most daunting part of the job. The most direct path may not be the best or even pracitical way in to the cab. 👍 Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Moresmoke Posted November 12, 2023 Report Share Posted November 12, 2023 Do you have any blank spaces in the dash cluster? Might be able to add the factory gauges. Another option would be a Scan Gauge whatever they call the heavy duty version. I know for certain that engine has a manifold pressure sensor, and would think it has exhaust temp also as it is an EGR engine. Quote Link to comment Share on other sites More sharing options...
