vacationer Posted February 14, 2023 Report Share Posted February 14, 2023 Well i just purchased a 2015 vovlo 730 . In side looks brand new non smoker my only concern is that it has wait for it 1 million miles on it. It has had lots of work done in the past year but he says the motor has never been opened up. It has top set done every year he said and he also uses pittsburg caytalist . had the dpf cleaned and baked he told me last year. Any signs i should look for in the future. Thanks Lee Quote Link to comment Share on other sites More sharing options...
Nigel Posted February 14, 2023 Report Share Posted February 14, 2023 One thing I’ve been doing to mine is spraying Krown or Rust Check into the drain holes in the bottom of the doors. The rust hasn’t got any worse since I started spraying about 8 years ago. Nigel Quote 2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30' Link to comment Share on other sites More sharing options...
Deezl Smoke Posted February 15, 2023 Report Share Posted February 15, 2023 Keep using the Pittsburgh and dont let the engine idle any more than absolutely needed. Any pictures? Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
jenandjon Posted February 15, 2023 Report Share Posted February 15, 2023 You should have a mechanic pull the oil pan and check the main bearings. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
