Easy Winterizing
I did a couple extra things for quick easy winterizing. Pictures attached. I added a 3/4 T to my hot water heater with a spigot for draining. I took the anode rod out and ran it straight through the T. Then I added to the low point drains with spigots so I wouldn't have to crawl underneath no more, or blow the lines out with compressor. I can now put antifreeze in drains, cut water off, open drains and leave. Even my Wife can do it now.
Edited by speedbugy
  Of course having RVed for 50 years I support safe effective additions or improvements that make things go faster or easier yayyyyyyyyyyy THANKS FOR THE POST. Hey whatever works for YOU is great... When I winterized I sometimes just removed the anode rod so I could inspect it and replace if necessary PLUS it seemed to allow for a better more rapid drain and discharge of any crud or accumulation VERSUS if only a trickle drain/discharge occurred and some sediment and particles got left behind WELL DRATS LOL
  I AGREE WITH LAPPIR  Its my opinion if the anode was fairly new and still full sized the drain/discharge may be a bit slower, while if its worn way down which I have seen it would drain faster maybe bring more crud out with it ??? Darn if I know lol
Thanks for the tip, glad it works for you it looks so easy peasey GOOD INFO
 John T
Edited by oldjohnt
Posted (edited)
The water drains pretty fast, I don't have to remove it, just open the spigot. It's on my general maintenance list to replace the anode rod May of each year so any remaining crude is flushed out.
Edited by speedbugy
  • 2 weeks later...
 Share
