Rotorhead Posted August 23, 2022 Report Share Posted August 23, 2022 Hello All, My system has been running about 125 psi in both the forward and rear tanks. That should be normal, correct? Today after the parked regen was done I noticed the rear tank was about 130 or so. Just a little high. question is, is that typical once in a while? Thanks, Chuck Quote Link to comment Share on other sites More sharing options...
dennisvr Posted August 24, 2022 Report Share Posted August 24, 2022 !30 lbs is normal. Dont be surprised if you notice that both tanks aren't the same pressures, that is OK too. They have a double check valve between them. Quote "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 24, 2022 Report Share Posted August 24, 2022 Parked Regen added a bunch of heat under the truck, right near the air tanks. Rear tank gained more Temp than front. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Rotorhead Posted August 24, 2022 Author Report Share Posted August 24, 2022 Awesome thanks! Quote Link to comment Share on other sites More sharing options...
Star Dreamer Posted August 27, 2022 Report Share Posted August 27, 2022 We have also noticed that the pressure is affected by the ambient temperature outside at least on our truck. Warmer temps seem to give us a higher pressure. I haven't paid attention to see if elevation makes a difference. Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
