Ray,IN Posted May 11, 2022 Report Share Posted May 11, 2022 Check this out for obtaining each axle weight: https://www.appweigh.com/how-it-works/ or TelTek or if you have tandem rear axles Right Weigh. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Larry Burkett Posted May 12, 2022 Report Share Posted May 12, 2022 It looks like it only works with air ride suspension. Quote Link to comment Share on other sites More sharing options...
sandsys Posted May 12, 2022 Report Share Posted May 12, 2022 19 hours ago, Larry Burkett said: It looks like it only works with air ride suspension. Plus, at $150 I can do a lot of CAT scale weighs; just be sure each axel is on a different scale plate. I tend to weigh each RV twice--once before buying and once fully loaded. If my load changes a lot I can still weigh again for less that the cost of a self-weigh system. I can see where this might be helpful for professional drivers who change loads frequently but not for RVers. Linda Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Kirk W Posted May 12, 2022 Report Share Posted May 12, 2022 21 hours ago, Larry Burkett said: It looks like it only works with air ride suspension. And it only gets axle weights, which is better than nothing but side to side is also very important and the best choice is individual wheel weights such as Smart Weigh or RVSEF give you. There are at least a few private individuals who have the service too, such as RV Weigh. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ray,IN Posted May 13, 2022 Author Report Share Posted May 13, 2022 Yes, I should've put this in the HDT forum, it's more appropriate. Trucks are not concerned about individual wheel-end weights unless an off-center load is obvious. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
