GlennWest Posted December 22, 2021 Report Share Posted December 22, 2021 Anyone had this happen. I can crank car, drive it just not turn off assy position to remove key. Acts like shifter not in park. Had to remove negative cable so not drain battery Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rickeieio Posted December 22, 2021 Report Share Posted December 22, 2021 Several of us have had this, or similar issue. Do a search about "smart key" and you'll find it. Nigel posted a link to the page in the manual. If you have the manual, look on...page 94? Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Jim & Wilma Posted December 22, 2021 Report Share Posted December 22, 2021 Glenn, probably easiest way to find post on how to fix is search for the word “torx”. Good luck. Quote Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted December 22, 2021 Report Share Posted December 22, 2021 I’ve removed the inner lock and threw it in the trash, this will never happen to me again! A very easy job to do after you get the plastic off the column cover, the interlock is mounted underneath the ignition switch and has two wires going to it I did this a year ago. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted December 22, 2021 Author Report Share Posted December 22, 2021 (edited) 29 minutes ago, Hewhoknowslittle said: I’ve removed the inner lock and threw it in the trash, this will never happen to me again! A very easy job to do after you get the plastic off the column cover, the interlock is mounted underneath the ignition switch and has two wires going to it I did this a year ago. Did it affect computer any when you removed it? Thank you very much for this info. Mine is a 2017. Same as yours Edited December 22, 2021 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted December 22, 2021 Report Share Posted December 22, 2021 No lights or check engine light, it just will shift without the key. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted December 22, 2021 Author Report Share Posted December 22, 2021 Cool. Thanks a million Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted December 22, 2021 Report Share Posted December 22, 2021 Your welcome. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted December 22, 2021 Author Report Share Posted December 22, 2021 Fixed during lunch break Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
