Slixter Posted September 15, 2021 Report Share Posted September 15, 2021 I have a 2012 Volvo 780. I want to put my dash cam near the top of the windshield but the only power in the overhead console (CB and Acc, plug) is direct to the battery. Has anyone removed the left or right side trim from the forward pillars? I tried but felt like I was going to break something. If. Can remove it I can feed power down through there. Quote Link to comment Share on other sites More sharing options...
Steve from SoCal Posted September 16, 2021 Report Share Posted September 16, 2021 Don't you want constant power? Fuse the power source in the overhead. Many cams record while parked if they sense motion. Quote 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
Slixter Posted September 16, 2021 Author Report Share Posted September 16, 2021 5 minutes ago, Steve from SoCal said: Don't you want constant power? Fuse the power source in the overhead. Many cams record while parked if they sense motion. I’ve always set my cams to shut down when not moving Quote Link to comment Share on other sites More sharing options...
rynosback Posted September 16, 2021 Report Share Posted September 16, 2021 I tucked, pushed in my wire just under the headliner and pillar cover and then run it to my cigarette lighter. But I manually plug it in when traveling and unplug it when parked. Quote 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
Wrknrvr Posted September 16, 2021 Report Share Posted September 16, 2021 If your cam is on 24/7. You could catch a actor that was not supposed to be near your truck. I would take power off the cb wires and fuse them. Then let it on. Just thinking , Vern Quote Link to comment Share on other sites More sharing options...
