George the greek Posted April 18, 2021 Report Share Posted April 18, 2021 (edited) I asked about tires in an other post and got good idea what to buy. Today was interesting got about 1,700 miles since I started this trip last week. Just about the time I was getting off the road to take on fuel I heard a noise, no idea what it was just a noise. While taking on fuel I was doing my usuall walk around and noticed one rear tire on camper looked quite low. It was down to 12 lbs After fueling I pulled out of the way and went to work changing out to the spare. There was a semi lube and repair shop next door so I rolled it over and got permission to pump air into it and check for leaks with soapy water. Tire checked out OK but have a pin hole On the inside of rim. If I had access to a welder Id have put a spot of weld on the pin hole. I did have some JB weld if it holds air in the morning Ill keep it as a spare if it leaks it goes in The dumpster. Needless to say a new set of tires and maybe one new rim is going to happen ASAP Edited April 18, 2021 by George the greek Spelling Quote Link to comment Share on other sites More sharing options...
rpsinc Posted April 18, 2021 Report Share Posted April 18, 2021 Sounds like you are making the correct decision. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted April 18, 2021 Report Share Posted April 18, 2021 2 hours ago, George the greek said: Just about the time I was getting off the road to take on fuel I heard a noise, no idea what it was just a noise. While taking on fuel I was doing my usuall walk around and noticed one rear tire on camper looked quite low. It was down to 12 lbs Do you think that the two might be related? Anyway it is good that you caught it before it caused any damage. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted April 18, 2021 Report Share Posted April 18, 2021 Sounds like time for a TPMS. Quote Link to comment Share on other sites More sharing options...
