GlennWest Posted March 4, 2021 Report Share Posted March 4, 2021 Saw this on Facebook. Victron is coming out with a 120/240v unit. This will eliminate need for 2 inverts for a lot of us. Don't know what wattage they will be yet. Quote Link to comment Share on other sites More sharing options...
oldjohnt Posted March 4, 2021 Report Share Posted March 4, 2021 Glenn, with so many 50 Amp RV's out there and with some that may even use full 240 for say a clothes dryer etc. I THINK THATS A GOOD MARKETING IDEA John T Quote Link to comment Share on other sites More sharing options...
GlennWest Posted March 4, 2021 Author Report Share Posted March 4, 2021 Saves a lot of clutter. Before one had to pair two units. Quote Link to comment Share on other sites More sharing options...
aknavy Posted March 5, 2021 Report Share Posted March 5, 2021 Would be nice. I only "need" the smaller 3k inverter, but would like to get rid of the smart phase selector that I'm using to tie it into the whole coach. If they do a 5k, I'd upgrade a bit, depending on cost. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted March 5, 2021 Author Report Share Posted March 5, 2021 I would get a 8k if they come out with that. They rate in VA instead of watts so that about a 7k unit. If not will get the Schneider 6800w. Quote Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted March 5, 2021 Report Share Posted March 5, 2021 Glen, it will be a 3000vs Multi Plus unit only. As far as VA goes, take a close look at the specs. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted March 5, 2021 Author Report Share Posted March 5, 2021 (edited) Only info I found was on Facebook. Not found it anywhere else. But 3k va is not much Edited March 5, 2021 by GlennWest Quote Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted March 5, 2021 Report Share Posted March 5, 2021 LOL, I can send you the specs on it but Victron is starting to come around. When you look at Magnum inverters, they state maximum watts which equals Volt-Amps and that is true for a purely resistive load. A Victron inverter lists the watts taking into account a .8 power factor. The end result of two inverters with the same VA rating is that they both will produce the same power to a load. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted March 5, 2021 Author Report Share Posted March 5, 2021 (edited) Yes, but if they don't go higher on watts, what's the use. 7k would run everything in my rv including electric fryers. For me that is. Be good for those that don't need that much. Schneider rates there 6800 as watts. Edited March 5, 2021 by GlennWest Quote Link to comment Share on other sites More sharing options...
lappir Posted March 8, 2021 Report Share Posted March 8, 2021 On 3/4/2021 at 7:38 PM, GlennWest said: Only info I found was on Facebook. Not found it anywhere else. But 3k va is not much I no longer do Facebook, if you get some other location for info, please share. I am very interested in a 120/240 volt inverter with my mini split system. Rod Quote Link to comment Share on other sites More sharing options...
GlennWest Posted March 8, 2021 Author Report Share Posted March 8, 2021 (edited) Only place I found was on a closed group on facebook. Also suppose to be on market in a month or so. Concerning your mini split, you could run it off a transformer. Then it would run on 30 amp circuit. That what I did. Edited March 8, 2021 by GlennWest Quote Link to comment Share on other sites More sharing options...
GlennWest Posted March 8, 2021 Author Report Share Posted March 8, 2021 (edited) https://www.facebook.com/groups/2589581644599315/permalink/3525105351046935/?comment_id=3526456560911814&reply_comment_id=3526529104237893¬if_id=1614961460598685¬if_t=group_comment&ref=notif This is a closed group so don't know if this link works for you. Only info I have Edited March 8, 2021 by GlennWest Quote Link to comment Share on other sites More sharing options...
Jaydrvr Posted March 8, 2021 Report Share Posted March 8, 2021 28 minutes ago, GlennWest said: https://www.facebook.com/groups/2589581644599315/permalink/3525105351046935/?comment_id=3526456560911814&reply_comment_id=3526529104237893¬if_id=1614961460598685¬if_t=group_comment&ref=notif This is a closed group so don't know if this link works for you. Only info I have Yeah, you can't see it without joining, so I joined. Looks like a fun page. Jay Quote Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted March 8, 2021 Report Share Posted March 8, 2021 Rod, I sent the spec sheet on that inverter to your yahoo email account. David Quote Link to comment Share on other sites More sharing options...
GlennWest Posted March 8, 2021 Author Report Share Posted March 8, 2021 8 minutes ago, Jaydrvr said: Yeah, you can't see it without joining, so I joined. Looks like a fun page. Jay Lot of good info on Robs group. Don't get all the facebook hype either. Quote Link to comment Share on other sites More sharing options...
lappir Posted March 11, 2021 Report Share Posted March 11, 2021 On 3/8/2021 at 11:10 AM, GeorgiaHybrid said: Rod, I sent the spec sheet on that inverter to your yahoo email account. David Got it thanks. It's a bit complicated for my eyes for some reason and I'm not sure it will work as I think it should. I may check into the "Transformer" but I need to decide what to do with the house battery bank soon and I'd like to replace the Inverter at the same time. There are also some other electrical issues I need to have evaluated by a professional, I am not sure who exactly though. Rod Quote Link to comment Share on other sites More sharing options...
lappir Posted March 11, 2021 Report Share Posted March 11, 2021 On 3/8/2021 at 9:40 AM, GlennWest said: Only place I found was on a closed group on facebook. Also suppose to be on market in a month or so. Concerning your mini split, you could run it off a transformer. Then it would run on 30 amp circuit. That what I did. Could you send me info on your transformer? Thanks, Rod Quote Link to comment Share on other sites More sharing options...
GlennWest Posted March 12, 2021 Author Report Share Posted March 12, 2021 (edited) https://www.amazon.com/dp/B00CLYFNU0/ref=twister_B06Y3L52H8?_encoding=UTF8&psc=1 I had mistakingly posted the 1000 watt. I'm using the 2000 watt. It runs cool. Edited March 12, 2021 by GlennWest Quote Link to comment Share on other sites More sharing options...
