Alie&Jim's Carrilite Posted March 3, 2021 Report Share Posted March 3, 2021 In 2014, I installed a 4 camera system on our 5th wheel and 1 camera on the truck. The connector cable was similar to the pic below but is was a 3 camera system on the RV. I have replaced 2 of the coil cables and spliced in a 6-way round plug and receptacle. The last cable got chewed recently by squirrels or birds and I need a replacement that is more durable than what's shown below. Suggestions? Quote Link to comment Share on other sites More sharing options...
Jim & Wilma Posted March 3, 2021 Report Share Posted March 3, 2021 Jim, assume these are the umbilical cables between the fifth and truck. We use a the standard 7 pin RV connector/cable for our three cameras. Has worked well for five years with no discernable signal degradation. Has advantage of being relatively cheap and common part. I spray the connector and receptacle every year or so with Boeshield T9 to fight corrosion. Quote Link to comment Share on other sites More sharing options...
Chad Heiser Posted March 3, 2021 Report Share Posted March 3, 2021 My voyager system uses commercial 7 pin round connecters and a commercial coil cable between them. It is very durable and has been in use on the truck for nearly 9 years with no degradation (but not full time use). Quote Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted March 4, 2021 Author Report Share Posted March 4, 2021 22 hours ago, Jim & Wilma said: Jim, assume these are the umbilical cables between the fifth and truck. We use a the standard 7 pin RV connector/cable for our three cameras. Has worked well for five years with no discernable signal degradation. Has advantage of being relatively cheap and common part. I spray the connector and receptacle every year or so with Boeshield T9 to fight corrosion. I hadn't thought about using a standard 7-way type connector. How did you wire from the individual camera cables to the 7pin? 19 hours ago, Chad Heiser said: My voyager system uses commercial 7 pin round connecters and a commercial coil cable between them. It is very durable and has been in use on the truck for nearly 9 years with no degradation (but not full time use). Thanks Chad, Quote Link to comment Share on other sites More sharing options...
Jim & Wilma Posted March 4, 2021 Report Share Posted March 4, 2021 Jim, I used one of these cable assemblies for the fifth wheel side and a companion receptacle on the truck side. Each of our cameras have the following 4 wires: Power (+12 vdc) Ground Video Audio I tied all the camera Power wires to a single terminal and likewise with the Ground wires to another terminal. That leaves 5 of the 7 terminals for video and audio. In our case we have three videos and I didn’t tie in any of the audios, so we’re left with two unused terminals. On both the truck and fifth wheel I used terminal strips in weather proof enclosures to combine and breakout the wires. Quote Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted March 5, 2021 Author Report Share Posted March 5, 2021 23 hours ago, Jim & Wilma said: Jim, I used one of these cable assemblies for the fifth wheel side and a companion receptacle on the truck side. Each of our cameras have the following 4 wires: Power (+12 vdc) Ground Video Audio I tied all the camera Power wires to a single terminal and likewise with the Ground wires to another terminal. That leaves 5 of the 7 terminals for video and audio. In our case we have three videos and I didn’t tie in any of the audios, so we’re left with two unused terminals. On both the truck and fifth wheel I used terminal strips in weather proof enclosures to combine and breakout the wires. Thank you! As soon as I read about using a 7-way cable, I figured a terminal strip would work. Putting on in the enclosure would be nice. Quote Link to comment Share on other sites More sharing options...
palmeris Posted March 5, 2021 Report Share Posted March 5, 2021 Rear view safety has a selection of cables and connectors. Quote Link to comment Share on other sites More sharing options...
