trimster Posted August 13, 2020 Report Share Posted August 13, 2020 (edited) So, I'm getting input & output NOx sensor engine warning error codes. SA 16 DTC P220f93 NOx sensor series 1 sensor 1 SA 16 DTC P22FE00 NOx sensor Row 1 sensor 2 I'm assuming the Sensor 1 is the input and Sensor 2 is output. 664k miles. Not sure if the previous owner changed them. Can these sensors be cleaned? Or do they just die? As well, buy aftermarket (mucho cheaper) or OEM (take out a loan)? Bob Edited August 14, 2020 by trimster Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
DesertMiner Posted August 13, 2020 Report Share Posted August 13, 2020 Best to change them. You may have a total of three NOX sensors. Quote Link to comment Share on other sites More sharing options...
trimster Posted August 14, 2020 Author Report Share Posted August 14, 2020 DesertMiner... There only seems to be 2. OEM eqiv. $380-450 Aftermarket $175-240 Checked the soot level. It's well below the 'A' marker so the computer won't let me force a parked regen. I guess after I replace these, I have to visit the dealer to reset the engine fault? Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Seniramsu Posted August 14, 2020 Report Share Posted August 14, 2020 When mine failed i purchased them and replaced them myself and yes.........had to take it to the dealer to clear the fault and force a regen. Quote 2013 Volvo 780 "Grunt" D13 I-Shift w/ ET Hitch 2016 Cyclone 4200 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 14, 2020 Report Share Posted August 14, 2020 The reset can be done by any service tech with the appropriate software on a laptop. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
trimster Posted August 16, 2020 Author Report Share Posted August 16, 2020 Appears that there's 2. Intake and exhaust. Good oem $389 -480 ea. Aftermarket $160 - 239 Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted August 16, 2020 Author Report Share Posted August 16, 2020 Got the sensors & they are installed. Off to the dlr Monday to get the code cleared. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted August 18, 2020 Author Report Share Posted August 18, 2020 Volvo dlr forced a code clearing & regen. Engine warning light is gone. Used aftermarket NOx sensors. Fingers crossed they will last. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Marty Main Posted February 9, 2022 Report Share Posted February 9, 2022 Bob, I have similar faults codes. How has the After-Market sensors performed? Quote Link to comment Share on other sites More sharing options...
trimster Posted February 9, 2022 Author Report Share Posted February 9, 2022 Lasted about 18 months then failed. Volvo charges $250 core charge if you don't return factory original (if they do the work, which i had them do. On the road.) I'm not sure why they should cost $450 ea. Other than they can. The aftermarket ones were not dosing the DEF properly. My DEF useage has gone up after the factory sensors were installed. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
