Deekon Posted June 9, 2020 Report Share Posted June 9, 2020 ? How do you change a victron inverter into 240v? Quote Link to comment Share on other sites More sharing options...
GlennWest Posted June 9, 2020 Report Share Posted June 9, 2020 48 minutes ago, Deekon said: ? How do you change a victron inverter into 240v? Transformer Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rpsinc Posted June 9, 2020 Report Share Posted June 9, 2020 1 hour ago, Deekon said: 240v 240VAC or 24VDC?? I'm confused. Quote Marcel Link to comment Share on other sites More sharing options...
Al F Posted June 9, 2020 Report Share Posted June 9, 2020 2 hours ago, Deekon said: ? How do you change a victron inverter into 240v? More details would really help. The subject of your post is "solar", but you write "Victron Inverter". An inverter takes 12V from battery and "inverts" it to 120V AC power. Solar generally has a solar "controller" to take the power from the solar panels and insures the output is proper for the batteries. Quote Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
Chad Heiser Posted June 10, 2020 Report Share Posted June 10, 2020 Some Victron inverters can be run in parallel to produce 240 volt if you are willing to add a second inverter. Victron also makes 240 volt capable inverters if you want to replace your inverter. If you want to stick with what you have, then Glenn is correct, you will need a transformer to do the conversion. Quote 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
