ceeminor Posted September 25, 2019 Report Share Posted September 25, 2019 (edited) Hi All, I'm new to this forum but have been very impressed with the technical insight I've read so I thought I'd give my current issue a post to see if anyone had any insight. I own a 2015 Keystone Outback with a Dometic DM2652 Refrigerator that has recently lost all 12VDC power (no display lights, fridge lights, and doesn't work on electric or propane). I'm an electrical engineer and have read through the schematics and found that there is a thermofuse between the J4 pin and 12VDC terminal block I can jumper out that completely solves the problem. However, I know that a thermofuse is a safety device and don't want to leave it jumpered out forever. My issue is that I don't know how to access the thermofuse that has popped. It is NOT the one located on the burner chimney. This one is located (I believe) within the refrigerator itself, atleast that's where I have chased the wire to before I lose it. I have attached an image of the schematic with the thermofuse I'm currently jumpering out and trying to find circled. Does anyone know how I can access this to change it? Or is this some fatal flaw in the design and I'll have to buy a new refer someday? Thanks for the help! Edited September 25, 2019 by ceeminor Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted September 25, 2019 Report Share Posted September 25, 2019 (edited) Real quick I think they are talking about the thermistor on the fins. That controls the unit to operate or not. My first thought,. Vern my next thought is i am wrong. Edited September 25, 2019 by Wrknrvr Quote Link to comment Share on other sites More sharing options...
oldjohnt Posted September 25, 2019 Report Share Posted September 25, 2019 Sorry NO I don't know where its at but hope to learn from someone on here. HOWEVER I'm happy to meet a fellow Electrical Engineer on here especially one who posts a schematic yayyyyyyyyyyyyyyyyyy Best wishes John T BSEE,JD currently in Indiana Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted September 25, 2019 Report Share Posted September 25, 2019 This may help with diagnostics on your unit. http://bryantrv.com/docs2/docs/1252service.pdf . Safe Travels,. Vern Quote Link to comment Share on other sites More sharing options...
SCClockDr Posted September 25, 2019 Report Share Posted September 25, 2019 (edited) Howdy Sorry you are having issues. Below is a youtube video for a different model Dometic but May provide a clue as to what you are looking for. (Red wire into a black plastic tube) Edited September 25, 2019 by SCClockDr Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 25, 2019 Report Share Posted September 25, 2019 In looking at the schematic that is in my service manual for a 2652, I see a very different schematic than what you have shown. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
ceeminor Posted September 25, 2019 Author Report Share Posted September 25, 2019 1 hour ago, SCClockDr said: Howdy Sorry you are having issues. Below is a youtube video for a different model Dometic but May provide a clue as to what you are looking for. (Red wire into a black plastic tube) Unfortunately this is the thermofuse I have already checked. This fuse was functioning properly. The thermofuse I'm looking for is located somewhere else within the refer. Thanks for your help though! Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 25, 2019 Report Share Posted September 25, 2019 Kirk, your manual is from an older version. Ceeminor, the thermal fuse I'm familiar with looks like a resistor, connected via spade terminals, with a clear plastic tube to protect from short circuits. This is represented in your schematics by item "Y". Item "F", I have no experience with. Item Y should be found close to the firebox. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
ceeminor Posted September 25, 2019 Author Report Share Posted September 25, 2019 1 hour ago, Kirk W said: In looking at the schematic that is in my service manual for a 2652, I see a very different schematic than what you have shown. Interesting. Are you sure you're looking at the DM2652 and not the RM? I got the model number off of my refrigerator then found it directly in the provided manual. Quote Link to comment Share on other sites More sharing options...
ceeminor Posted September 25, 2019 Author Report Share Posted September 25, 2019 1 minute ago, Darryl&Rita said: Kirk, your manual is from an older version. Ceeminor, the thermal fuse I'm familiar with looks like a resistor, connected via spade terminals, with a clear plastic tube to protect from short circuits. This is represented in your schematics by item "Y". Item "F", I have no experience with. Item Y should be found close to the firebox. Thanks for the info! Do you know where I can find this firebox? I chased the wire from the 12VDC terminal block all the way into the inside of the back of the refrigerator and lose it there as I can't see the interior part of the refrigerator. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 25, 2019 Report Share Posted September 25, 2019 23 minutes ago, ceeminor said: Thanks for the info! Do you know where I can find this firebox? I chased the wire from the 12VDC terminal block all the way into the inside of the back of the refrigerator and lose it there as I can't see the interior part of the refrigerator. The box that has the fire inside. Base of the chimney stack. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 25, 2019 Report Share Posted September 25, 2019 https://www.tandyonline.com/128-c-thermal-fuse.html Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
ceeminor Posted September 25, 2019 Author Report Share Posted September 25, 2019 Thanks for everyone's help! This forum is great! Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 25, 2019 Report Share Posted September 25, 2019 4 hours ago, ceeminor said: Interesting. Are you sure you're looking at the DM2652 and not the RM? That is it exactly. The link that I posted was for the RM series. I don't recall having dealt with any of the DM series but I did find them listed on the net for sale. I sent an email to Chris Bryant to as about them as there seems to be a big difference. 4 hours ago, Darryl&Rita said: The box that has the fire inside. Base of the chimney stack. I looked at the fuse in your link and it looks exactly like the one that water heaters have for safety if the burner should flash-back. Is it the same? Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
rocksbride Posted September 25, 2019 Report Share Posted September 25, 2019 (edited) CEEMINOR, This thread might be helpful. Start with first post, even though the link opens near the end of the thread. Enjoy the read: http://www.rvnetwork.com/topic/130797-no-power-on-dometic-fridge-model-rm-2652/?tab=comments#comment-937589 Edited September 27, 2019 by rocksbride Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 26, 2019 Report Share Posted September 26, 2019 If you are still watching this thread, I just conversed with Chris Bryant of Bryant RV Service and he tells me a bunch that I didn't know about these refrigerators. First, on the issue of RM series versus the DM: "Because they just used a single digit for the year, they were making 2015 units with the same serial numbers as 2005 units, so they changed the model number to DM." That left me with questions about the fact that I found several different schematics for those refrigerators and when I asked about that he said "That thermofuse is enclosed in heatshrink, located right next to the burner- part of the recall, which turned in to a redesign. They really have a bunch of different wiring schemes, which are different product numbers, rather than model numbers. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
