Wrknrvr Posted February 6, 2019 Report Share Posted February 6, 2019 I will be changing the two thermostats in our n14 in a few weeks. The parts are on the way and will install them in a few weeks. On the Cummins n14 there is a water transfer tube that has to be taken off at the same time. There is a o'ring at each end of that tube that should be replaced. But I am curious as to what to use when the new o'rings are installed. Pure silicone lube or what. I have searched the web but so far have not found the answer. Thanks in advance,. Vern Quote Link to comment Share on other sites More sharing options...
spindrift Posted February 6, 2019 Report Share Posted February 6, 2019 (edited) https://www.movingupgaragedoors.com/lubriplate-l0034-094-motor-assembly-grease?_vsrefdom=adwords&gclid=CjwKCAiAqOriBRAfEiwAEb9oXRy4SX1sTD4o2Kc2B97N-RXNWWVQKyz9nwHYENOxozFwPCYSM7hi8hoCmY0QAvD_BwE FYI, Cummins supplies this product to it's technicians. Edited February 6, 2019 by spindrift Quote Link to comment Share on other sites More sharing options...
Imurphy907 Posted February 6, 2019 Report Share Posted February 6, 2019 Not sure what is recommended. But I have used anything from motor oil, vaseline, silicon spray, axle grease. basically, anything to lube it up upon assembly. Quote Link to comment Share on other sites More sharing options...
ARGO Posted February 6, 2019 Report Share Posted February 6, 2019 KY ? Quote Link to comment Share on other sites More sharing options...
rickeieio Posted February 6, 2019 Report Share Posted February 6, 2019 We've always used white lithium. It's made by Lubri-Plate....... Might be the same stuff link by Tom. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted February 7, 2019 Author Report Share Posted February 7, 2019 Thanks for the good info. It will be a few weeks till I get to do that repair. Safe Travels,. Vern Quote Link to comment Share on other sites More sharing options...
