HWH Air Bag Leveling
RNF03
HWH air bag leveling system 2000 will not stay in travel mode.  System is on 2004 Country Coach Allure with Cummins 370.  The manual and auto leveling function works with no problems.  Any help would be appreciated.  Thank you.
  • 3 weeks later...
If you find the ride height valve is properly engaged, and working. A method that can be used it to get coach into traveling mode, then in the fuse panel below the driver seat bay, pull the fuse to the leveling system. It will remain in the position it's in. If it will not go into Traveling mode automatically, then adjust it manually - and then pull the fuse. (Good Idea to go into Travel Mode, and then go measure the distance from the top of the tires to the wheel well fenders bottom. (About the size of my fist for my steers, a bit more for my rears.).
And get on the call back list to HWW, as they will provide support to those who are stranded first. So since you hopefully should be able to travel by pulling the fuse, it might be a few days until they get back with you. They'll walk you thru some diagnostics, which should let you know what's going on:)!
Best to you,
Smitty
(04 Allure 40', Serial 31017)
Be safe, have fun,
Smitty
  • 1 month later...
On 11/22/2018 at 1:10 AM, RNF03 said:
Solution.  The threaded rod on the ride height valve was disconnected.  Got new rod and installed.  Problem fixed.  Thanks.
Have you measured your ride height since? Many things depend upon the correct setting, including wheel alignment.
