dosbeagles Posted September 25, 2018 Report Share Posted September 25, 2018 Hi, reading about slide units I see there are several types. The first one is the in wall vs through the wall. I thought all slides were both in and through the wall. What is the difference between the two classifications and which one is newer technology and your opinion as to which one is better and why. Thanks in advance for your help. Chris & Joni The Beagles now 3 Daphne, Ace and Flash looking 2016 Acura MDX http://jnctravelogue.wordpress.com Link to comment Share on other sites More sharing options...
Fulltimer51 Posted September 25, 2018 Report Share Posted September 25, 2018 I agree with you. How could a slide not be in and through the wall? Thats why they are "slide outs". Even a slide in slide will be through the wall. George2011 F350 6.7PSD CC 4X4 DRW Lariate2015 Mobile Suites 41 RSSB4 5th Wheel Link to comment Share on other sites More sharing options...
Dutch_12078 Posted September 25, 2018 Report Share Posted September 25, 2018 I think they're referring to "surface" through the wall versus "flush" in the wall slides. Surface slides when retracted still protrude slightly past the exterior wall and seal around the opening with an obvious lip. Flush slides retract into a recessed wall opening presenting a smooth flush exterior wall appearance, with the seal against a recessed lip. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
FL-JOE Posted September 25, 2018 Report Share Posted September 25, 2018 It has to be just different manufacturers/dealers have different terminology when describing slides. When building any RV with a slide there really is only one way. You have a wall with a opening and a pre-built "box" gets set inside that opening, and abra cadabra…….we have a slide out.... Joe & Cindy Newmar 4369 Ventana Pulling 24' enclosed (Mini Cooper, Harley, 2 Kayaks) Link to comment Share on other sites More sharing options...
dosbeagles Posted September 25, 2018 Author Report Share Posted September 25, 2018 The Lippert website touts the qualities of both in wall slides and through the frame slides. But I am still not seeing the benefits of one over the other. I believe the through the frame slide and through the wall slides are the same. Chris & Joni The Beagles now 3 Daphne, Ace and Flash looking 2016 Acura MDX http://jnctravelogue.wordpress.com Link to comment Share on other sites More sharing options...
Kirk W Posted September 25, 2018 Report Share Posted September 25, 2018 4 minutes ago, dosbeagles said: I believe the through the frame slide and through the wall slides are the same. Might the difference be in where the hardware is located? Some in the walls of the slide and others have it under the floor of the slide? Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
mptjelgin Posted September 25, 2018 Report Share Posted September 25, 2018 17 minutes ago, Kirk Wood said: Might the difference be in where the hardware is located? Some in the walls of the slide and others have it under the floor of the slide? I imagine something like this is the case. The Schwintek slide system has the mechanism completely enclosed in the wall, with no beams or other mechanisms located below the slide. Many other systems support the slide on a pair of beams that are driven either hydraulically or electrically (rack and pinion) with the support beams exposed below the floor and in either penetrating the trailer frame or riding above it. Perhaps this is the distinction between the "in the wall" (Schwintek) and "through the wall (frame?) systems. Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
rvrev2 Posted September 29, 2018 Report Share Posted September 29, 2018 NuWa called them "glide rooms." 2002 NuWa HitchHiker II 31 FKTG, Onan Generator, HWH Levelling, RVFlexArmor roof 2005 Chevy Silverado 2500 Crew Cab, Long Bed, SRW, 8.1L B&W Companion Fifth Wheel Hitch Me and Mama and the fur-kid: Prince - chihuahua-pug mix Link to comment Share on other sites More sharing options...
