Shallow Draft Posted June 4, 2018 Report Share Posted June 4, 2018 My 04 Volvo has a passenger door issue. I cannot open it from the outside. It works fine from the inside and the locks seem to work as they should with the remote and manually.. The door handle has tuck in the past but as soon as I opened it from the inside it returned to near normal. It has always seemed a bit stiff but worked. Looking for ideas thanks 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
Pat & Pete Posted June 4, 2018 Report Share Posted June 4, 2018 Sounds like a little lube would go a long way . I don't know about your Volvo , but , you might have to pull the panel to do a decent job or maybe there's a few holes available in the back post side , close to the handle . That's the way it's been on the trucks I've had to work on . Goes around , comes around . Link to comment Share on other sites More sharing options...
Shallow Draft Posted June 4, 2018 Author Report Share Posted June 4, 2018 Thanks I will give that a try in the morning. It does feel like it is sticking.. I will try some silicone spray and see if that helps. 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
atv_idiot Posted June 4, 2018 Report Share Posted June 4, 2018 Same thing happened to my buddy's 780. When we pulled the door apart the actuator rod from the outer handle to the latch was dangling. There is a plastic end busted off the rod. Super easy fix. Volvo Part # is 8143976 and my cost was 12.63 Also found this by searching the part # https://class8truckparts.com/volvo-truck-rod-8143976.html Link to comment Share on other sites More sharing options...
Shallow Draft Posted June 4, 2018 Author Report Share Posted June 4, 2018 58 minutes ago, atv_idiot said: Same thing happened to my buddy's 780. When we pulled the door apart the actuator rod from the outer handle to the latch was dangling. There is a plastic end busted off the rod. Super easy fix. Volvo Part # is 8143976 and my cost was 12.63 Also found this by searching the part # https://class8truckparts.com/volvo-truck-rod-8143976.html This may be the case if I pull on it any harder. So far it just seems stuck. I suspect that if it had the broken end then the handle would be free to move. I am trying to avoid taking the door apart. I will try the lube first then take the door panel off. 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
Parrformance Posted June 4, 2018 Report Share Posted June 4, 2018 https://www.amazon.com/dp/B078YQVG65/ref=asc_df_B078YQVG655498759/?tag=hyprod-20&creative=395033&creativeASIN=B078YQVG65&linkCode=df0&hvadid=241954052572&hvpos=1o5&hvnetw=g&hvrand=14894258213403039493&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012166&hvtargid=pla-451751566722 The pliers in this kit make removing the door panel a breeze. I purchased mine from Harbor Freight. Purchase the window crank handle tool as well if the truck does not have a passenger side power window. https://www.amazon.com/Dorman-76951-Window-Handle-Removal/dp/B000CO96VI/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1528110807&sr=1-2-catcorr&keywords=window+crank+handle+remover 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Shallow Draft Posted June 4, 2018 Author Report Share Posted June 4, 2018 3 hours ago, Parrformance said: https://www.amazon.com/dp/B078YQVG65/ref=asc_df_B078YQVG655498759/?tag=hyprod-20&creative=395033&creativeASIN=B078YQVG65&linkCode=df0&hvadid=241954052572&hvpos=1o5&hvnetw=g&hvrand=14894258213403039493&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012166&hvtargid=pla-451751566722 The pliers in this kit make removing the door panel a breeze. I purchased mine from Harbor Freight. Purchase the window crank handle tool as well if the truck does not have a passenger side power window. https://www.amazon.com/Dorman-76951-Window-Handle-Removal/dp/B000CO96VI/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1528110807&sr=1-2-catcorr&keywords=window+crank+handle+remover thank you looks like something we should have 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
Shallow Draft Posted June 4, 2018 Author Report Share Posted June 4, 2018 Thanks to all. A little lube and all is good 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
Parrformance Posted June 4, 2018 Report Share Posted June 4, 2018 20 minutes ago, Shallow Draft said: Thanks to all. A little lube and all is good There is a joke to be had, but I am going to take the high road here😁. 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Pat & Pete Posted June 4, 2018 Report Share Posted June 4, 2018 4 hours ago, Parrformance said: There is a joke to be had, but I am going to take the high road here😁. Prudent , choosing the road less persecuted . Not as much fun , but ... LOL Goes around , comes around . Link to comment Share on other sites More sharing options...
