dan412 Posted February 23, 2017 Report Share Posted February 23, 2017 I'm looking at this for my 780 do you guys think it will work? Super Titan 3000 Weld-on Trailer Hitch w/ 3 Inch Receiver Opening, 20K Code: 38211 Retail:$1,149.78 Price: $617.95 Link to comment Share on other sites More sharing options...
DanBree Posted February 23, 2017 Report Share Posted February 23, 2017 That will depend on what you are planning on pulling, and if it can be adjusted to fit to an HDT frame. This hitch has a very specific width requirement. When I looked at this for my truck, I needed to make sure it would fit onto with my existing rv 5th wheel hitch frame and light assembly, and have the receiver fit below the light setup. In my case, the widths did not quite work, and the receivers wouldn't clear my light assembly. I had a local company install a weld-on 16k hitch with a 2" receiver and the receiver sits just below my light assembly. I can send pics if you PM me your email. Link to comment Share on other sites More sharing options...
MrSeas Posted February 23, 2017 Report Share Posted February 23, 2017 Do you really need that high of a capacity hitch? 3" adapters are a bit $$$ . Double check the width and finished height of this hitch. You can get 15 to 16k capacity on a less expensive receiver! Link to comment Share on other sites More sharing options...
lockmup68 Posted February 23, 2017 Report Share Posted February 23, 2017 or if you already have a custom built bed with 3/16-1/4 plate, just weld in a receiver tube and add some bracing. Link to comment Share on other sites More sharing options...
dan412 Posted February 25, 2017 Author Report Share Posted February 25, 2017 Ordered my trailer hitch today should be here in a couple of weeks. Link to comment Share on other sites More sharing options...
