Danabrodbeck Posted February 15, 2017 Report Share Posted February 15, 2017 It seems like every time I pick up a caulking gun to seal something, the tube of caulk is always hardened in the tube and useless. I have a room of butyl tape left over from a Fantastik Fan installation that I did that works great for sealing up th end of an opened tube of caulk or self leveling roof sealer. It seems to extend the life of a tube much longer than other methods that I've tried. Link to comment Share on other sites More sharing options...
gjhunter01 Posted February 15, 2017 Report Share Posted February 15, 2017 I usually stick a 16d nail into the caulk tube end and then wrap with electrical tape, usually good for 6 months or longer. Greg Link to comment Share on other sites More sharing options...
rpsinc Posted February 21, 2017 Report Share Posted February 21, 2017 Great ideas!! Marcel Link to comment Share on other sites More sharing options...
wildmandmc Posted February 21, 2017 Report Share Posted February 21, 2017 have always used a nail in the end to keep it soft. but anything to keep out the air should work 2000 Itasca Horizon DP (Got Total During Irma). Vice President of Charlotte County Defenders LE MC http://charlotte.defenderslemc.com/ Link to comment Share on other sites More sharing options...
ogaddcb Posted February 21, 2017 Report Share Posted February 21, 2017 Last summer the crew that put in the new windows at the recreation hall where I volunteer used see link to large wing wire connectors. They said just screw them on like normal, plus the wing wire connectors help keep the tube neck clean. They used them on all the chalk tube like containers including silicon/liquid nails tubes for months. 2022 F-250 4X4 LB SC Godzilla V8 /2014 Northwood Nash 17K/SKP098347 Link to comment Share on other sites More sharing options...
cpaulsen Posted February 21, 2017 Report Share Posted February 21, 2017 Last summer the crew that put in the new windows at the recreation hall where I volunteer used see link to large wing wire connectors. They said just screw them on like normal, plus the wing wire connectors help keep the tube neck clean. They used them on all the chalk tube like containers including silicon/liquid nails tubes for months. I use large wire connectors also. Link to comment Share on other sites More sharing options...
dewilso Posted February 21, 2017 Report Share Posted February 21, 2017 All good ideas, thanks for starting the thread. Dave W. KE5GOH Stuck in the 70's --- In E. Texas Link to comment Share on other sites More sharing options...
ALLOY Posted February 21, 2017 Report Share Posted February 21, 2017 The finger tip from the latex or nitrile gloves that I'll wear when dong the caulking. 2011 Cameo 34SB3 Link to comment Share on other sites More sharing options...
Pat & Pete Posted February 21, 2017 Report Share Posted February 21, 2017 I use a screw , instead of a nail . Seems to have been a good move as I rarely have to deal with a 'cured' caulk tube tip . Goes around , comes around . Link to comment Share on other sites More sharing options...
