Heavymetal Posted January 17, 2017 Report Share Posted January 17, 2017 There are a bunch of 30 amp sites open in the campground at the RV show 23-31 and I can't believe they would not want to rent them ( vendor or not ) so if you are coming to the show give them a call and see if you can snag one. The number is (813)663-3663 2016 Western Star 5700xe (Pathfinder) DD15 555hp w/12 speed automatic 3:05 diffs 2005 Newmar Mountain Aire 38RLPK 2 Great Danes Link to comment Share on other sites More sharing options...
rdickinson Posted January 17, 2017 Report Share Posted January 17, 2017 Called,only vendors even if left vacant. Could boondock but generator rad fan not running. Overheats Could bypass switch, wire direct if I had the parts or go to Kubota dealer if local. 356 miles out on I-10 Link to comment Share on other sites More sharing options...
rdickinson Posted January 17, 2017 Report Share Posted January 17, 2017 Also called Kubota dealers, no one wants to work on it. Less than helpful. May e I'll try to find a mobile Rv mechanic. There are probably others wit mechanical issues. Link to comment Share on other sites More sharing options...
Heavymetal Posted January 17, 2017 Author Report Share Posted January 17, 2017 Also called Kubota dealers, no one wants to work on it. Less than helpful. May e I'll try to find a mobile Rv mechanic. There are probably others wit mechanical issues. Drews RV tech, local #(813)645-7870 they are working around the show campgrounds. 2016 Western Star 5700xe (Pathfinder) DD15 555hp w/12 speed automatic 3:05 diffs 2005 Newmar Mountain Aire 38RLPK 2 Great Danes Link to comment Share on other sites More sharing options...
rdickinson Posted January 17, 2017 Report Share Posted January 17, 2017 There are a bunch of 30 amp sites open in the campground at the RV show 23-31 and I can't believe they would not want to rent them ( vendor or not ) so if you are coming to the show give them a call and see if you can snag one. The number is (813)663-3663 Got spot B4 I'll have the truck on stealth mode. Link to comment Share on other sites More sharing options...
rdickinson Posted January 17, 2017 Report Share Posted January 17, 2017 Drews RV tech, local #(813)645-7870 they are working around the show campgrounds. They're not interested. Only working on emergencies for those staying at the show Link to comment Share on other sites More sharing options...
Heavymetal Posted January 17, 2017 Author Report Share Posted January 17, 2017 Got spot B4 I'll have the truck on stealth mode. Where is B-4? 2016 Western Star 5700xe (Pathfinder) DD15 555hp w/12 speed automatic 3:05 diffs 2005 Newmar Mountain Aire 38RLPK 2 Great Danes Link to comment Share on other sites More sharing options...
Heavymetal Posted January 17, 2017 Author Report Share Posted January 17, 2017 Called,only vendors even if left vacant. Could boondock but generator rad fan not running. Overheats Could bypass switch, wire direct if I had the parts or go to Kubota dealer if local. 356 miles out on I-10 What do you need to bypass switch? 2016 Western Star 5700xe (Pathfinder) DD15 555hp w/12 speed automatic 3:05 diffs 2005 Newmar Mountain Aire 38RLPK 2 Great Danes Link to comment Share on other sites More sharing options...
rdickinson Posted January 18, 2017 Report Share Posted January 18, 2017 Wire Toggle Connectors Link to comment Share on other sites More sharing options...
Heavymetal Posted January 18, 2017 Author Report Share Posted January 18, 2017 Wire Toggle Connectors I have wire, connectors and some rocker switches plus there is a Napa truck shop about a mile away. We lost a head light on the way here so I had to pick one up and they had toggle switches if a rocker want work. 2016 Western Star 5700xe (Pathfinder) DD15 555hp w/12 speed automatic 3:05 diffs 2005 Newmar Mountain Aire 38RLPK 2 Great Danes Link to comment Share on other sites More sharing options...
Jim & Wilma Posted January 18, 2017 Report Share Posted January 18, 2017 We'll in the parking lot tomorrow and will be carrying soldering iron, heat shrink, spade lugs and the like. And there's nothing I like better than figuring out how to bypass a circuit so let me know if I can assist. Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
rdickinson Posted January 18, 2017 Report Share Posted January 18, 2017 69 miles I have some things I want to check manual and fuses/breakers. I have a fuse holder plus fuses Link to comment Share on other sites More sharing options...
rdickinson Posted January 18, 2017 Report Share Posted January 18, 2017 Mr GPS pulled a D&R 1% trick cost 45 minutes Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted January 18, 2017 Report Share Posted January 18, 2017 I think most of us will be asleep when you get get here Roger. if we leave before you get up, we will see you at the show. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Heavymetal Posted January 18, 2017 Author Report Share Posted January 18, 2017 I think most of us will be asleep when you get get here Roger. if we leave before you get up, we will see you at the show. Did I see you drive in today? If so where did you park! I made a trip around the outer road this evening and did not see any HDT's but I saw some coming in today. 2016 Western Star 5700xe (Pathfinder) DD15 555hp w/12 speed automatic 3:05 diffs 2005 Newmar Mountain Aire 38RLPK 2 Great Danes Link to comment Share on other sites More sharing options...
rdickinson Posted January 18, 2017 Report Share Posted January 18, 2017 B4 across from the red Volvo flattop and down the opposite row to your left. The show is massive unlikely we will connect. I've not met you My US cell 772 584 1273 I need to sort out intermittent left turn signal a d generator. If generator can't be fixed properly, the Cummins people will take a look. I got in about 1030 local..i think. Not sure, I've jumped 2 or 3 time zones,in the last 3 days. Cell says 1140 so 1030 is about right. The rig needs to be unhooked and the car unloaded and wiped down. I set the countdown odometer to 4k miles about 60 miles into the trip. It zeroed ou about 300 miles ago.. Long run. I should be up about 5 am so call me before you leave. There are a bunch of emails need to be done asap What's the Wi fi password here pleaze? R Link to comment Share on other sites More sharing options...
lappir Posted January 18, 2017 Report Share Posted January 18, 2017 Still haven't decided if I will bring the truck or car. Will be leaving after work Friday and it's a little less than a 4 hour trip. Either way I plan to sleep in the parking lot and be up early, hopefully before the crowd starts flowing in Saturday. Undecided about staying Saturday night too. Will there be any issue arriving after 9pm? I've never stayed on site before. I know there is an extra parking (extended) fee, is the entrance staffed all night? Looking forward to seeing everyone there. Rod White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
Heavymetal Posted January 18, 2017 Author Report Share Posted January 18, 2017 B4 across from the red Volvo flattop and down the opposite row to your left. The show is massive unlikely we will connect. I've not met you My US cell 772 584 1273 I need to sort out intermittent left turn signal a d generator. If generator can't be fixed properly, the Cummins people will take a look. I got in about 1030 local..i think. Not sure, I've jumped 2 or 3 time zones,in the last 3 days. Cell says 1140 so 1030 is about right. The rig needs to be unhooked and the car unloaded and wiped down. I set the countdown odometer to 4k miles about 60 miles into the trip. It zeroed ou about 300 miles ago.. Long run. I should be up about 5 am so call me before you leave. There are a bunch of emails need to be done asap What's the Wi fi password here pleaze? R You made it to the fairground last night? What kind of parts do you need this morning to fix your genset? 2016 Western Star 5700xe (Pathfinder) DD15 555hp w/12 speed automatic 3:05 diffs 2005 Newmar Mountain Aire 38RLPK 2 Great Danes Link to comment Share on other sites More sharing options...
Heavymetal Posted January 18, 2017 Author Report Share Posted January 18, 2017 Still haven't decided if I will bring the truck or car. Will be leaving after work Friday and it's a little less than a 4 hour trip. Either way I plan to sleep in the parking lot and be up early, hopefully before the crowd starts flowing in Saturday. Undecided about staying Saturday night too. Will there be any issue arriving after 9pm? I've never stayed on site before. I know there is an extra parking (extended) fee, is the entrance staffed all night? Looking forward to seeing everyone there. Rod Everyone have been really nice! You can get a parking pass plus a overnight pass for one night or the whole show. 2016 Western Star 5700xe (Pathfinder) DD15 555hp w/12 speed automatic 3:05 diffs 2005 Newmar Mountain Aire 38RLPK 2 Great Danes Link to comment Share on other sites More sharing options...
rdickinson Posted January 18, 2017 Report Share Posted January 18, 2017 IRod, what direction are you coming from? I'm in an Rv park in Bushnell, North of Tampa. If I'm still here you could bunk in the trailer. There is a fold out sofa. Just bring a sleeping bag. Link to comment Share on other sites More sharing options...
rdickinson Posted January 18, 2017 Report Share Posted January 18, 2017 I'm at an rv park in Bushnell north, not at the fairground. Without the generator I can't drycamp.so am not going to risk it. With a residential fridge and small freezer, batteries drain fast. If gen fan circuit gets bypassed, wire, switch, connectors, maybe heatshrink. Some I already have. Once my eyeballs have detached from the back of my head, I'll have a look at the manual to see if there is a schematic for that system. I could bring the truck today if I'm not able to fix it myself. Also need to get trailer intermittent left turn signal fixed. Trailer stays here. The problem is in the junction box/pin box area where the EZConnector,connects to the trailer. I can see the red wire. Feels like an inline with heatshrink. I have Randy wrists X2 so am not able to work around hard 90 corners. Link to comment Share on other sites More sharing options...
rdickinson Posted January 18, 2017 Report Share Posted January 18, 2017 I'm at an Rv park North of fairground not at Fairground. I'll bring the truck with Smart on it. Send phone #. We could meet up. Randy is on his way either today or tomorrow. Link to comment Share on other sites More sharing options...
Heavymetal Posted January 18, 2017 Author Report Share Posted January 18, 2017 Roger my number is (936)348-0360 2016 Western Star 5700xe (Pathfinder) DD15 555hp w/12 speed automatic 3:05 diffs 2005 Newmar Mountain Aire 38RLPK 2 Great Danes Link to comment Share on other sites More sharing options...
rdickinson Posted January 18, 2017 Report Share Posted January 18, 2017 Have Rv tech coming to Rv park Friday for turn signal. I'll try again with truck disconnected so I don't have to bend backwards. I'll be at the show later after washing the rig...4300 miles of road grime. Retinas have just dislodged from back of my head How these truckers put on 700 to 900 miles a day is beyond me. Passed a toad abandoned by the side of the road a few days back. The front end was completely ground down to the tow bar connection points. Bottom half of both wheels and air dam etc completely gone. He did leave 2 safety triangles behind the car. Something like this was on UTUBE. Roger Link to comment Share on other sites More sharing options...
SIBERNUT Posted January 18, 2017 Report Share Posted January 18, 2017 Anybody at the show, do me a favor? If you see the vendor from Irvine Shade & Door (Shade Man), ask him what the "show discount" is on orders. Don't mention me, etc. Just trying to see if I got the "best" deal. TKS! You all enjoy, maybe next year........................ 2000 Volvo 635 A/S, N-14 Cummins"The Phoenix"'03 KA 38KSWB http://s918.photobucket.com/user/sibernut/library/?sort=6&page=1Furkids- Sibe's CH. Sedona & Tseika Link to comment Share on other sites More sharing options...
