TireHobby Posted September 19, 2016 Report Share Posted September 19, 2016 A lot of people make some mistakes when “plus sizing” up from their Original Equipment tires. The reference provided below provides the correct procedures for most all situations. Just use the one that applies to your situation. It’s a 2006 document that was written to comply with the current tire industry rules changes of 2007. It follows all FMVSS regulations and, most important, all tire industry standards for replacing OE tires fitted by manufacturers building vehicles in accordance with FMVSS regulations. http://www.tiresafety.com/images/Tire%20Replacement%20Manual.pdf p.s. FMCSA regulations do not apply to tire fitments - any design - for RV trailers. 38' fiver - Dodge Dually AKA: FastEagle USN Retired - DOD Retired - SSA Retired Link to comment Share on other sites More sharing options...
jerryneal Posted September 24, 2016 Report Share Posted September 24, 2016 Task complete. New 17.5s all around with Goodyear G114s. Trailerandtire was great to work with. First trip this Saturday with a run through Atlanta. Looking forward to seeing how the new tires perform. Trip through Atlanta ... not so much. https://www.flickr.com/gp/jerryneal/a44v61 Jerry and Joan 2014 Ford F350 with 6.7 turbo, TrailerSaver 2014 40' Heartland Gateway Fifth wheel iLoveRVlife.com Link to comment Share on other sites More sharing options...
297550 Posted September 24, 2016 Report Share Posted September 24, 2016 i am going to replace my tires on my 11 drv 38 ft 5th.i now have goodyears 215 75r 17.5 load range H. what are some recommends for replacements of these tires, they are 6 years old . should i go to an st type or stay with lt type? jack what are they using on the big new Horizons? Assuming your tires are GY G114's, I'd say you've got about as good as it gets. Assuming you're not using more than 75% of the available tire capacity, I'd stick with what you have. BTW, ST tires are all speed rated at 60 MPH ... maximum. The LT G114's that you already have are speed rated S (75 MPH). 2017 KZ Durango Gold 381REF, 8K morRYDE IS, Disc brakes, 17.5" Hi Spec Aluminum Wheels w Goodyear G114 H rated tires 2016 F350 King Ranch DRW, 3.73, 4x4, Super Duty Crew Cab, 6.7L Powerstroke Diesel. 26,760 CGVW Link to comment Share on other sites More sharing options...
BigTexRex Posted September 25, 2016 Report Share Posted September 25, 2016 Assuming your tires are GY G114's, I'd say you've got about as good as it gets. Assuming you're not using more than 75% of the available tire capacity, I'd stick with what you have. BTW, ST tires are all speed rated at 60 MPH ... maximum. The LT G114's that you already have are speed rated S (75 MPH). My trailer tires are rated for 75 mph...Continental Rex & Karen Libre y pobre en La Casa Rodante Link to comment Share on other sites More sharing options...
Kevin H Posted September 25, 2016 Report Share Posted September 25, 2016 Attached is a pdf of the Goodyear inflation chart. GY-Inflation.pdf The richest are not those who have the most, but those who need the least. Link to comment Share on other sites More sharing options...
297550 Posted September 25, 2016 Report Share Posted September 25, 2016 My trailer tires are rated for 75 mph...Continental Using them on a trailer doesn't make them trailer tires. Tires labeled as ST (special trailer tires) are speed rated at 60 mph by law. Many LT (light truck) tires are used on trailers. Most LT tires are speed rated "S" (75mph). 2017 KZ Durango Gold 381REF, 8K morRYDE IS, Disc brakes, 17.5" Hi Spec Aluminum Wheels w Goodyear G114 H rated tires 2016 F350 King Ranch DRW, 3.73, 4x4, Super Duty Crew Cab, 6.7L Powerstroke Diesel. 26,760 CGVW Link to comment Share on other sites More sharing options...
BigTexRex Posted September 25, 2016 Report Share Posted September 25, 2016 Using them on a trailer doesn't make them trailer tires. Tires labeled as ST (special trailer tires) are speed rated at 60 mph by law. Many LT (light truck) tires are used on trailers. Most LT tires are speed rated "S" (75mph). My tires (Continentals HTL2 Eco Plus) are specifically for trailers. Rex & Karen Libre y pobre en La Casa Rodante Link to comment Share on other sites More sharing options...
lockmup68 Posted October 27, 2016 Report Share Posted October 27, 2016 bumping this as I am getting ready to get rims and tires. Was asking at local discount tire and the guy is an old OTR driver and he said, "no brainer, you should try Hercules, all I used to run on my Pete." 75mph speed rating, 12k lbs load per tire @ 125 psi, $195 each. Here are the specs: https://simpletire.com/hercules-235-75r17.5-59546-tires Hercules H-902 235/75R17.5 Size UTQG Max. Load Inflation Pressure Tread Depth Tire Weight Rim Width Range Sect. Width Tread Width Overall Diam 235/75R-17.5 N/A 12,621 lbs 125 psi 17/32nds 63 lbs 7" 9" N/A 31" 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Randyretired Posted October 28, 2016 Report Share Posted October 28, 2016 The local COOP sells Hercules tires and highly recommends them. They said the Hercules seldom have problems and they perform as well as any of the other brands they sell for a smaller price. I have not owned any yet. Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
