ANG0225 Posted June 26, 2016 Report Share Posted June 26, 2016 Can anyone recommend a good deodorizer or the like to kill the odor coming out of sink. Especially bad after dumping Link to comment Share on other sites More sharing options...
Bob A Posted June 26, 2016 Report Share Posted June 26, 2016 We use pinsol, also if u have a vent in the sink cupboard it may need cleaning 2014 jayco siesmic 3914 1998 volvo 610, singled short ( bought in 2005) 14 speed volvo tranny 2014 Toyota yaris Link to comment Share on other sites More sharing options...
Devilishjim Posted June 26, 2016 Report Share Posted June 26, 2016 suction from draning must have sucked water out of trap... dump a lil chemical for holding tank in drain and add water Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted June 26, 2016 Report Share Posted June 26, 2016 You should have no odor coming out of your sink due to the P-trap that has water in it to stop odors. Most likely your air admittance valve just down stream of the trap has failed. They are easy (usually) to replace. They unscrew and you screw a new one in its place. Here is what they generally look like: http://images.meredith.com/diy/images/2009/02/p_SCP_215_06.jpg You can get them at most big box stores like Home Depot, Lowes, etc. Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted June 26, 2016 Report Share Posted June 26, 2016 suction from draning must have sucked water out of trap... dump a lil chemical for holding tank in drain and add water If that is the case the air admittance valve is stuck shut. There water should not ever get sucked out of a trap. Link to comment Share on other sites More sharing options...
Pat & Pete Posted June 26, 2016 Report Share Posted June 26, 2016 Any decent hardware store will carry the valves as well . Goes around , comes around . Link to comment Share on other sites More sharing options...
Kirk W Posted June 26, 2016 Report Share Posted June 26, 2016 If that is the case the air admittance valve is stuck shut. There water should not ever get sucked out of a trap. I'd highly suspect that this is the right answer as those devices do wear out and need to be replaced. You can see just what it looks like and how to replace one by visiting this link to our website. They are available at Lowe's, Home Depot, or most any plumbing supply store. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Barbaraok Posted June 27, 2016 Report Share Posted June 27, 2016 In the mean time, dump some baking soda into the sink and water dissolve in and down the drain. Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
Zulu Posted June 27, 2016 Report Share Posted June 27, 2016 In the mean time, dump some baking soda into the sink and water dissolve in and down the drain. I'm of the sodium hypochlorite persuasion -- dump some bleach down the drain. SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
budeneighe Posted June 27, 2016 Report Share Posted June 27, 2016 Bleach is a bad idea if you are in a park on a septic system. RVBuddys Journal Our progress into full-timing.Budd & Merrily ===-> SKP# 088936 Other Websites:---> Hub of all my blogsClifford - 2000 VNL64T770 :: DakotR - 1999 C40KS King of the Road :: $PRITE - 2013 Smart Passion w/cruise Link to comment Share on other sites More sharing options...
Zulu Posted June 27, 2016 Report Share Posted June 27, 2016 Bleach is a bad idea if you are in a park on a septic system. As long as you don't dump a whole quart down the drain, bleach will break down into salt & water in short order. Plus, bleach doesn't hurt RV plumbing. SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
Barbaraok Posted June 27, 2016 Report Share Posted June 27, 2016 Sodium bicarbonate is better at sweetening drains, helps to buffer tank solution, and better for holding tanks. But I'm just a chemist, so what do I know. Barb Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
