Scrap Posted June 14, 2016 Report Share Posted June 14, 2016 So I'm digging up an old thread from 2 years ago but it was a good one. Did you guys do the measuring at your rally and come up with a wire and fuse size? I'm hoping 2/0 and something megafuse-able? Triple digit amps? http://www.rvnetwork.com/index.php?showtopic=109852 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 14, 2016 Report Share Posted June 14, 2016 Scrap, In a word, NO. We did not get to do the measurements. However, I used 2/0 cable for a run of about 8 ft and a 300 amp t fuse. My fuse in upper right in pic. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Scrap Posted June 15, 2016 Author Report Share Posted June 15, 2016 Thanks Suite! Link to comment Share on other sites More sharing options...
Jim & Wilma Posted June 15, 2016 Report Share Posted June 15, 2016 Here's the current data from Warn's 4000 Lb winch under the Specifications tab. If you're pulling a Smart up 12 foot ramps, we're looking at about 500 lb line pull drawing 40.7 amps. Blue Sea has a real easy to use chart to help select wire gauge. For a Smart car application, 2 or 4 AWG should be sufficient, depending upon length. Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 15, 2016 Report Share Posted June 15, 2016 Here's the current data from Warn's 4000 Lb winch under the Specifications tab. If you're pulling a Smart up 12 foot ramps, we're looking at about 500 lb line pull drawing 40.7 amps. Blue Sea has a real easy to use chart to help select wire gauge. For a Smart car application, 2 or 4 AWG should be sufficient, depending upon length. Wow, massive overkill on my part then! 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rdickinson Posted June 15, 2016 Report Share Posted June 15, 2016 Herrin used a 2 ton on my rig which even with single pull was plenty, a bit jerky but still plenty. I've gone with a snatch block and double pull. Link to comment Share on other sites More sharing options...
Jim & Wilma Posted June 15, 2016 Report Share Posted June 15, 2016 Wow, massive overkill on my part then! Not really. It's just twice circular mills which halves the IR (voltage) drop, never a bad thing. Herrin used a 2 ton on my rig which even with single pull was plenty, a bit jerky but still plenty. I've gone with a snatch block and double pull. Roger, you may want to look at the ground return path. My bed had welded studs on the frame to connect the ground circuits. That's ok for lights, but for the winch I ran a cable back to the battery negative vs using the frame as a return path. Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
Big5er Posted June 15, 2016 Report Share Posted June 15, 2016 Roger, you may want to look at the ground return path. My bed had welded studs on the frame to connect the ground circuits. That's ok for lights, but for the winch I ran a cable back to the battery negative vs using the frame as a return path. Hmm, something I might wanna look at also MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 15, 2016 Report Share Posted June 15, 2016 "Roger, you may want to look at the ground return path. My bed had welded studs on the frame to connect the ground circuits. That's ok for lights, but for the winch I ran a cable back to the battery negative vs using the frame as a return path." I did the same, Jim, again with 2/0. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
