MsChrissi Posted May 12, 2016 Report Share Posted May 12, 2016 Does anybody have pictures of the inside rear bulkhead of a VNL-770 with the interior upholstery removed? Before we tear into the bulkhead and interior to install the flanges for the "walk through" between the cab and the MH box it would be nice to see what surprises we are in for. The header of the flange is just below the upper bunk support but by the patterns of spot welds there are both horizontal and vertical doublers in the area. The only wires we are aware of are the one white courtesy light which we will repurpose the wiring for a light on each side above the fuel fillers and an LED strip each side under the body so you can see where you are stepping and maybe avoid fuel or grease on the ground while refueling. There are also cables for the table release mechanism which will be going away with this mod. Thanks! Link to comment Share on other sites More sharing options...
Star Dreamer Posted May 12, 2016 Report Share Posted May 12, 2016 I think Henry helped put a rear walk thru door in one some time ago. Hopefully Phoenix will comment regarding it. Dave 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
NoDirectionHome Posted May 12, 2016 Report Share Posted May 12, 2016 http://www.wheelingtruck.com/wp-content/uploads/VNL670-v-ProStar.pdf Page 48 gives just a hint "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740 Link to comment Share on other sites More sharing options...
HERO Maker Posted May 12, 2016 Report Share Posted May 12, 2016 That would actually be page 25 on the PDF file. It is for a 670, but might be the same. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 12, 2016 Report Share Posted May 12, 2016 Ms. Chrissi, Look at "Adding Sleeper Windows" under "Projects" in the Resource Guide. May help you. Looks pretty "beefy" back there. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
MsChrissi Posted May 12, 2016 Author Report Share Posted May 12, 2016 Thanks guys , yes it looks kinda beefy back there. Glad we are well within the two verticals. Surprised how thick it is, guessing from pics maybe 1.5~2" Link to comment Share on other sites More sharing options...
