removing decals
Try a heat gun ( carefully ) or maybe a hair drier will be enough . The idea is to soften the adhesive while pulling the decal off . Best to start at a corner or tip and lay the decal back on itself while removing , as opposed to pulling straight away from the surface . WD40 will remove most any adhesive left on the surface . Wash the surface with soap and water afterward .
Having bought my brother's delivery HHR that had decals all over it(about 7 year old decals), I tried just about everything. Heat Gun, Plastic razor blades, 3M eraser wheel, chemicals, fingernails, ect ect. The things that worked best, hmmmmm the 3M eraser is good just be careful with it, it can leave marks. The heat gun in conjunction with the plastic razor's were a close second. I had practically the whole vehicle to work on.
We just removed alot of the decals on our new to us MH. Razor blades and heat work but one of the decal and adhesive wheels works the best. DO NOT get one of the cheap one like from HF. Go to an automotive paint shop and get one. I have a good one and works great. Bought a cheap one and all it does is gum up the gel coat. Get what you pay for. They do last a long time too.
I used a small decal remover from HF. It plugs in to heat a razor blade. Removed all of the decals on our Teton and painted new ones. If the decals are old and cracked pulling with a heat gun can be frustrating. The little decal remover just slides along but care must be taken to avoid nicking the gel coat. The 3M Eraser worked on some of our decals but left a mess on others. I used lacquer thinner to remove the glue. The HF decal remover is cheap, around $15. It took 2 to do our 40' 5er. I haven't tried some of the other methods so I can't comment on them.
Well having removed decals from one side of our Alfa fiver, I looked like the medicine man. The stripes of different colors and some with gold spreckels all seemed to react differently. I used plastic razor blades (from NAPA) with a long handle scraper from O'Reilleys, plastic putty knives, adjustable temp heat gun from Harbor Freight,(aka Big Boys Toy Store) watch temps, Goo Gone, Goof Off and several others I don't remember. It does make it "slightly" easier working on the sunny side. It seemed like the dark colored stripes I could just get under them with the plastic razor blades and the heat gun. Went fairly well, just had to start over going from crack to crack. Lighter colors were more labor intensive for a lack of a better word. And the gold spreckles, well let's just say I made many new words up!
The previous owner of my truck did a good job of getting a LOT of decals removed from it before I purchased it. Chuck, are you still here? What was your secret? Don't know if I have the photo of before but will look.
Rod
Make that tons of decals! ;)
To the best of my knowledge Chuck fell off the planet several years ago.
BTW, you might try looking in the HDT Resource Guide as at one time there were links to topics related to decal removal.
Mineral spirits, acetone..... but for some odd reason I have the best results with carb cleaner.....which, if I am informed correctly is a cocktail of acetone, MEK, xylene, toluene and a few other "health products".
I'll have to try that! I have to remove decals on a regular basis and have never found any thing that worked really good!
I've taken off decals with the guidance of a buddy who has a sign shop. Use plastic razor blades as they won't gouge the fiberglass. I used a heat gun/hair dryer to "encourage" the decal to come off and also used the plastic razor blades.
After the decals were removed I used Goo Gone to remove the adhesive. Finally, I followed up with acetone to remove the Goo Gone to assure that the fiberglass was clean and ready for new decals.
