WaywardWaylander Posted March 9, 2016 Report Share Posted March 9, 2016 Looking at the specs on some 5th wheels, something about the weight capacities doesn't add up. I'll try to explain... The example 5th wheel has a shipping weight of 13,140. It has an indicated carrying capacity of 3745. Am I wrong to add these two to reach a GVWR of 16,885? Assuming that's correct, there are two axels rated at 7000 apiece. This would seem to suggest a max carrying capacity of 14,000. Is that right? If so, this is a trailer with a GVWR of 16,885 and an axel rating of that is 2885 short of the GVWR. Am I missing something? Link to comment Share on other sites More sharing options...
Kevin H Posted March 9, 2016 Report Share Posted March 9, 2016 You're on the right track. One thing to consider is the weight that will be on the hitch. Subtract the hitch weight from the total and you should be under 14k. I had the same question on our 5th wheel when we went from a MH to the trailer. Good question. Link to comment Share on other sites More sharing options...
Dennis M Posted March 9, 2016 Report Share Posted March 9, 2016 The general rule is 20-25% of the total weight on the hitch, thus on the tow vehicle rather than the fiver axles. 20% of your 16,885 = 3,377. Thus 13,508 on your two 7k axles. My fiver for example has a GVWR of 20k and two 9k axles, thus I need at least 2k pin weight. Mine lands at 21% so I have 4,200 lbs pin weight - plenty of leeway. This is the reason we are always weighing our individual rigs so we can figure out exactly where the weight is sitting. Link to comment Share on other sites More sharing options...
Yarome Posted March 9, 2016 Report Share Posted March 9, 2016 Don't worry.. you're not alone. Weight ratings can be confusing. To start with, the dry/shipping weight is simply an estimate and a rigs actual weight generally varies.. as does the cargo capacity.. so those "published" weights are really kind of worthless in real life but are there to "get you in the ball park". The number you really want is the 5r's GVWR. From there you would get an actual weight of your 5r at the scales to be entirely accurate. It's generally best to have it loaded out as you would for a trip. From there you would subtract that weight from the GVWR to determine what additional cargo capacity you have remaining. The axle ratings are for "under tow".. not necessarily sitting under a static load, however, not all of your 5r's actual weight is being carried only on the axles. A portion of total weight will be carried on the hitch and should put you under the combined axle ratings. One addition point to note is that weight distribution of your rig must be closely adjusted.. as well as setting your 5r to tow level.. so that one axle and tire set is not loaded more heavily than the other. Link to comment Share on other sites More sharing options...
WaywardWaylander Posted March 9, 2016 Author Report Share Posted March 9, 2016 Ah HA! I didn't realize that needed to be factored in. Mystery solved! Thanks! Link to comment Share on other sites More sharing options...
Sehc Posted March 9, 2016 Report Share Posted March 9, 2016 I would never carry the GVW. Aim lower and well distributed. Link to comment Share on other sites More sharing options...
billr Posted March 10, 2016 Report Share Posted March 10, 2016 We find most units weighed when loaded for full time or snowbird travel run pretty close to GVWR on the sticker. Or maybe a tad or more... Over. Forget dry or empty weights as mentioned. It's the GVWR you want to use. Of course once your loaded and ready weigh your unit. Preferable by individual wheel. All the advise mentioned in the posts are right on. Link to comment Share on other sites More sharing options...
GlennWest Posted March 12, 2016 Report Share Posted March 12, 2016 Also watch tire ratings. Axles good for 14k, is tires? Link to comment Share on other sites More sharing options...
Al F Posted March 12, 2016 Report Share Posted March 12, 2016 Don't forget to include the weight of fresh water and black & gray water from the carrying capacity. Granted you may not always travel with full water & holding tanks, but there is a huge amount potential weight there. Water is ~8.3 pounds per gallon. 70 gallons of water is around 560 pounds of that carrying capacity. Link to comment Share on other sites More sharing options...
dragonpc Posted March 14, 2016 Report Share Posted March 14, 2016 I have a Jayco Featherweight Trailer that I just bought used. GAWR = 3300 pounds. Individual tires are rated at 1710 lbs each. Hitch weight is 415 lbs. GVWR is 3500. Is my tire capacity sufficient? It doesn't add up to the GVWR of 3500 lbs but it is in excess of the GAWR of 3300 (1710x2=3420). Link to comment Share on other sites More sharing options...
Phil D Posted March 15, 2016 Report Share Posted March 15, 2016 Because your tire capacity exceeds the rated GAWR, they're sufficient. Your GAWR plus the tongue weight rating of 415# exceeds the rated GVWR, and the tires need not account for that. Tongue/hitch weight on a travel trailer works just as the pin weight does in the above examples for fifth wheel trailers -- it's covered by the GVWR, but doesn't have to be accounted for in the GAWRs, of which the tires are a part -- since that portion of the trailer's weight is being transferred to the tow vehicle. Link to comment Share on other sites More sharing options...
