breister Posted December 18, 2015 Report Share Posted December 18, 2015 We are looking to remove the sofa sleeper from our Class A Windsor and replace it with 1 or 2 Stressless type recliners. If you buy the ones designed for RV's, do they come apart so you can get them into the RV? How about taking the sofa out? I don't need to remove the windshield do I? Thanks a lot for any advice. PS: Suggestions on where to purchase the chairs we are thinking of? Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted December 18, 2015 Report Share Posted December 18, 2015 If they are not going to be sold and just thrown away, a reciprocating saw with a 12" demo blade should work just fine making manageable pieces out of it.... I know our fifth wheel was ordered without furniture and the rear window had to come out to get the new sleeper sofa inside. Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted December 18, 2015 Report Share Posted December 18, 2015 Usually the backs come off. That might get it to a manageable size to get thru the door. Link to comment Share on other sites More sharing options...
docj Posted December 18, 2015 Report Share Posted December 18, 2015 We are looking to remove the sofa sleeper from our Class A Windsor and replace it with 1 or 2 Stressless type recliners. We have both a Stressless recliner and one of their sofas. Both fit through our front door without any problems. We did wrap the sofa in heavy plastic and put tape on any possible protrusion around the door, but there were no real problems getting it in. Ours is only ~72" long so it could be stood up going through the door. Quite a few pieces (arms, etc) can be removed from both the chairs and sofas, if necessary, to make it easier to get them in. Link to comment Share on other sites More sharing options...
Bill B Posted December 19, 2015 Report Share Posted December 19, 2015 Removed the sofa yesterday and put in one (of the 2 (backordered)) of the new recliners. Pull out sofa (older) came out with a rachet and set of sockets. Recliner went in in 2 pieces (shipped that way, no special order). Took longer to find the tools than to do the job. Well, also added 2 more receptacles in Wiremold behind the center table and the 2nd recliner. That took an hour or so. Link to comment Share on other sites More sharing options...
SWharton Posted December 19, 2015 Report Share Posted December 19, 2015 We did the same thing. Getting the recliners in was easier than getting the sofa out. Most of our time was spent bolting down the recliners so they would stay in place. We also added some wiremold and plugs. Link to comment Share on other sites More sharing options...
Al F Posted December 19, 2015 Report Share Posted December 19, 2015 I have pulled out sofas from 2 different motorhomes. Also put the sofa back in one MH when I went to sell it. I had to turn them on edge (not vertical) and they came out the door easy. Well they are heavy, but fit through the door fine. Putting a new one back in, well it depends on the size. Need to measure carefully before buying. The sofas did have to be unbolted from the floor. Link to comment Share on other sites More sharing options...
Kevin H Posted December 19, 2015 Report Share Posted December 19, 2015 There was no way our sofa-sleeper would fit through the door opening, plus, that thing was really heavy. The back folded forward to make into the bed so that meant there were two pivots. I turned it over and removed the bolts that were the pivots. We then had two manageable pieces that went through the door e-z-p-z, Good Luck - we don't miss that sofa at all. Link to comment Share on other sites More sharing options...
budeneighe Posted December 19, 2015 Report Share Posted December 19, 2015 Mine was both heavy and 1 piece. I just removed the door frame and it came out really easy. Same thing when I had to swap out the defunct Norcold 1200 refer with a residential model. Removing the door frame gave me another 4" in width to work with. Your inches may vary. Link to comment Share on other sites More sharing options...
Seeria Posted December 30, 2015 Report Share Posted December 30, 2015 Our sofa was dismantled pretty fast. Just undo the bolts and screws. Finding a recliner that can be dismantled enough to get through the door might be a problem. Still searching. Link to comment Share on other sites More sharing options...
SWharton Posted December 30, 2015 Report Share Posted December 30, 2015 We bought Lazyboys Pinnacle. Back comes off and goes through door easily. Have had them for 8-9 years now(maybe longer) and all is fine with them. Link to comment Share on other sites More sharing options...
jerryneal Posted December 31, 2015 Report Share Posted December 31, 2015 We replaced our dual recliner-love seat sofa. Backs came off the recliners and was able to take unit out in 3 sections. Pretty heavy. Replaced with an apartment sized sleeper. It's 82" wide but the trick was to find something that would fit in a 29" door. The apartment sized sofa was no problem...it was close. We love the new look. Brighter fabric and eleminated some of that dark leather-like look. Link to comment Share on other sites More sharing options...
