Bungapads Posted December 2, 2015 Report Share Posted December 2, 2015 I have 2011 Tiffin allegro red. We have replaced the leveling jacks twice since we got the coach. The right rear jack rises after we level. Does anyone know what caused this and how to fix it? Link to comment Share on other sites More sharing options...
pjstough Posted December 2, 2015 Report Share Posted December 2, 2015 What was wrong with your jacks that they had to be replaced? Unless you have a leaking hose or connection, the only way I know for the jack to raise without input from the controller is for the electric solenoid to not be shutting completely off. So I would suspect that either the solenoid is not properly tightened, it has failed internally, or the manual release valve on the back side is partially open. My experience is with our system on our 2005 Winnebago, you system could be a lot different. Link to comment Share on other sites More sharing options...
Kirk W Posted December 2, 2015 Report Share Posted December 2, 2015 What brand & model are the jacks? electrical or hydraulic? Link to comment Share on other sites More sharing options...
Bill Joyce Posted December 3, 2015 Report Share Posted December 3, 2015 When this happened to us, we replaced the solenoid for that jack and it fixed the problem. HWH has manuals with troubleshooting steps in them on their website, if you know your model number. We followed the troubleshooting steps in the manuall to determine it was the solenoid. Link to comment Share on other sites More sharing options...
Barbaraok Posted December 3, 2015 Report Share Posted December 3, 2015 What brand & model are the jacks? electrical or hydraulic? Uh, HWH is the brand, and they are hydraulic. Sure sounds like the solenoid. Link to comment Share on other sites More sharing options...
SIBERNUT Posted December 3, 2015 Report Share Posted December 3, 2015 Same problem. The little solenoids have a needle valve on the end, and ever since one of my jacks was replaced it leaked. I cleaned the needle & used lapping compound on the tip, helped a lot. BUT- what really helped was disconnecting a line & pumping out all the fluid, put in new. I am pretty sure there was dirt in the old fluid blocking the needle on the one that was replaced. (By a "technician" who wasn't smart enough to read the label to not fill the system unless fully retracted. A**H*** to the 10th power! What do you think happened inside my front bay & all my stuff in there?) YO', HWH - you think maybe you could put a filter in an otherwise good system? Oh no, it will never get dirt in it. Right! Talk to Ford Indy car engineers about that. And those solenoids aren't cheap Link to comment Share on other sites More sharing options...
Kirk W Posted December 3, 2015 Report Share Posted December 3, 2015 Uh, HWH is the brand, and they are hydraulic. Sure sounds like the solenoid. Sounds that way as I don't think that HWH makes anything but hydraulic. I wonder if it stops happening if they turn off power to the system? I would expect it to but................... I would be interesting to know why the jacks were replaced. Link to comment Share on other sites More sharing options...
fairway2002 Posted December 13, 2015 Report Share Posted December 13, 2015 When you replace are you using pipe tape at all? Never use tape. Brakes off is your system . Link to comment Share on other sites More sharing options...
SIBERNUT Posted December 13, 2015 Report Share Posted December 13, 2015 Why replaced? Leaking, Newmar warranty paid for it. I woulda' had a seal put in it but................. Link to comment Share on other sites More sharing options...
Dale P Posted December 16, 2015 Report Share Posted December 16, 2015 Depending on how the system works. Fluid In / Fluid out is reversible by the valve system. Extending the jack, fluid in one side, pushing extending the jack, while at the same time fluid is being pushed out the bottom. Once pump has stopped, valves are in the closed position thereby preventing the fluid from bleeding down. This will keep the jack in that position until the operation is reversed. Link to comment Share on other sites More sharing options...
SIBERNUT Posted December 17, 2015 Report Share Posted December 17, 2015 HWH is one line in, springs retract the piston when valve is opened (or when ca-ca gets in the valve). Link to comment Share on other sites More sharing options...
Rif Posted December 17, 2015 Report Share Posted December 17, 2015 The OP has not returned so we don't know if his problem is fixed. However, for anyone else with HWH issues, just call the company and ask for tech support. They are excellent and will walk you through the troubleshooting process. Sometimes they may have to call you back if all techs are busy, but they will get to you eventually. Link to comment Share on other sites More sharing options...
