mobilcastle Posted November 13, 2014 Report Share Posted November 13, 2014 I don't want to start a hitch war here. I am presently using a B&W Companion hitch to pull my 16K Heartland 5ver. I also have a mor/ryde pin box. We are full time and I am thinking of changing to an air hitch. Most of the time our setup seems to be fine but when I hit some interstate concrete highways near big cities it is horrible. Those of you that have air hitches I would like to know if the air hitch will eliminate most of this. I am looking at the Hensley trail saver BD3. I am open to looking at others. I will need to use a drop in Curt adapter or pull the B&W under bed ball system and install some standard rails.Thanks for your info, Steve Link to comment Share on other sites More sharing options...
TXiceman Posted November 13, 2014 Report Share Posted November 13, 2014 We are pleased with our Trailer Saver TS3. Friends have the Trail Air TriGlide pinbox and like it. I believe Trailer Saver has an adapter system to use with your B&W under mount bed hitch. Our trailer has the Demco Gide pinbox and the Mor/Ryde IS suspension system. Yet we do have some road sections that are so rough, we still have to drop to 40 mph and turn on the flashers. Our roads are in terrible shape and the goober-ment is not spending any money to properly repair or upgrade them due to wasted budget money. We have found the secondary roads to be generally smother than the Interstate system. The Interstate roads within city limits are particularly bad. Link to comment Share on other sites More sharing options...
GlennWest Posted November 13, 2014 Report Share Posted November 13, 2014 We got the Hitch Crafters 24k unit. They were the only ones that would make one to fit in the trough on my hauler bed. It uses the Hensely 32k head. Comes with air compressor and height sensor so I don't have to add or subtract air. You could use the 32k hitch. It is 20" wide. One they made for us is 17.5" wide. 12.5" high. Haven't towed yet. Sorry Link to comment Share on other sites More sharing options...
gg923 Posted November 13, 2014 Report Share Posted November 13, 2014 I have a TS3 and I really like it. It has an onboard compressor and I mounted the control switch & gauge in the cab which enables me to control/adjust the hitch as needed. I am using it with the MR Pinbox & MR IS suspension and rarely get any chucking (only on really bad roads). Link to comment Share on other sites More sharing options...
Bobq21 Posted November 13, 2014 Report Share Posted November 13, 2014 Hey Gene, how much air do you use in your hitch, just doing some comparing?Thanks,BobQ Link to comment Share on other sites More sharing options...
grumpydoc Posted November 13, 2014 Report Share Posted November 13, 2014 We too have the TrailerSaver air hitch and really like it and yes the trailer does ride better. But your impression of the ride in the truck will be the same, "this road is awful". The hitch you use will help the trailer ride better but does little or nothing for the ride in the truck IMO. So if you go to an air hitch don't be surprised is you can't tell much difference in the ride from the front seat of the truck. Best wishes, Jay Link to comment Share on other sites More sharing options...
marspec2003 Posted November 13, 2014 Report Share Posted November 13, 2014 I have used the Air Safe 25K hitch with the Binkley head for going on 7 years. I had to purchase a Reese adapter for the Ford system with the new truck or put in rails. The Air Safe has four air bags so it moves in all dimensions and ou can also adjust the hitch height. Agree with grumpydoc the hitch doesn't do much for the truck but even with the fillings in my teeth coming loose the fiver seems to do OK. Link to comment Share on other sites More sharing options...
mobilcastle Posted November 14, 2014 Author Report Share Posted November 14, 2014 Thanks for you answers. I guess I need to work around some of these cities on secondary highways. We are retired so I have plenty of time when travelling. I hope to see some of you down the road. Steve Link to comment Share on other sites More sharing options...
gg923 Posted November 14, 2014 Report Share Posted November 14, 2014 Hey Gene, how much air do you use in your hitch, just doing some comparing? Thanks, BobQ Bob, The TS3 has a 100# max PSI if I am not mistaken. I have to run 85 to 90 psi due to my pin weight (which I have been working to lower). There is a line on the TS hitches as an inflation guide. Mine takes about 80 to 85 psi to reach that line. Gene Link to comment Share on other sites More sharing options...
Nolan Posted November 14, 2014 Report Share Posted November 14, 2014 We have the TSLBSH Trailersaver now for ten years. Run it at about 60 psi to be level and on the line. We have run over lots of crappy roads. But the suspension and the air seats in the truck help a lot too. Link to comment Share on other sites More sharing options...
Pizzadude Posted November 15, 2014 Report Share Posted November 15, 2014 I have the Trailer Saver TS3 hitch along with the Trail Air tri-glide pinbox ( already had pinbox ) and it helped the ride all around. You still feel the truck hit the bumps, but don't feel the trailer hit them at all. Link to comment Share on other sites More sharing options...
Bill B Posted November 15, 2014 Report Share Posted November 15, 2014 Mobile - Air suspension on the truck, air for the cab, air for the seat, air hitch for the trailer, MorRyde IS on the trailer, good shocks on all of it, the roads are still bad. Ya cushion everything as best you can and Link to comment Share on other sites More sharing options...
roadfitter Posted November 16, 2014 Report Share Posted November 16, 2014 When it comes to the air ride hitches your pin weight is very important. Depending on the trailer the pin weight could be anywhere between 2000 lbs. and 8000 lbs., some less and some more. The point is regardless of which hitch brand you have getting higher than 85 psi or 85% of the bags capacity begins to diminish the effectiveness of the air ride hitch. Getting up into 85% or more inflation the bags begin to be just rubber isolators. This is one reason Trailer Saver offers the 3rd. bag up grade. I am on this edge with inflation to 75 psi. which brings me up to the white line set by TS. 3 rd. bag is on my bucket list. Having my rig weighed my pin weight is at 3500 lbs. We try not to run the interstates, terrible. We run the national hyws. ie: 12, 14, 24, 36, etc., we do go north and south to. These highways provide much better roads and places to pull off or spend the night at. HAPPY TRAILS & WE'LL WATCH FOR YA DOWN THE ROAD! roadfitter Link to comment Share on other sites More sharing options...
297550 Posted September 18, 2016 Report Share Posted September 18, 2016 I have a Hensley BD3 ... Love the ride, but more importantly, my 5th wheel trailer's FRAME loves the decreased stress. There are several very good reasons to have a quality air ride hitch, but the health of your frame might be the most important. Link to comment Share on other sites More sharing options...
garyl53 Posted September 20, 2016 Report Share Posted September 20, 2016 I tried a BD-3 to improve overall ride/handling of my '11 F350/'08 KS Challenger combo. I am experiencing chucking and a very harsh ride causing driver and passengers to be uncomfortable. My pin weight is about 2600#. The BD-3, although a very high quality hitch for sure, did not help even in combination with a Mor/Ryde RPB. I believe that the BD-3 would be more beneficial with pin weights above 3000#. Also I am wondering if the TS-3 model would be better at reducing chucking since any pushing or pulling between the trailer and the tow vehicle are transferred into vertical motion by the TS-3 and then handled by the TS-3 air bags. The BD-3 does not have this same design. I think that the air bag pin boxes (e.g. Fifth Airborne or Trailer Saver) may be more beneficial for pin weights under 3000# but I have not data to support my thinking other than what I have tried so far. I would like to hear others experience as well as any suggestions to address my current dilemma. Good Luck. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted September 21, 2016 Report Share Posted September 21, 2016 For an alternative. Has a B&W adapter. http://www.comfortridehitch.com/hi_model_245.html Link to comment Share on other sites More sharing options...
297550 Posted September 23, 2016 Report Share Posted September 23, 2016 I tried a BD-3 to improve overall ride/handling of my '11 F350/'08 KS Challenger combo. I am experiencing chucking and a very harsh ride causing driver and passengers to be uncomfortable. My pin weight is about 2600#. The BD-3, although a very high quality hitch for sure, did not help even in combination with a Mor/Ryde RPB. I believe that the BD-3 would be more beneficial with pin weights above 3000#. Also I am wondering if the TS-3 model would be better at reducing chucking since any pushing or pulling between the trailer and the tow vehicle are transferred into vertical motion by the TS-3 and then handled by the TS-3 air bags. The BD-3 does not have this same design. I think that the air bag pin boxes (e.g. Fifth Airborne or Trailer Saver) may be more beneficial for pin weights under 3000# but I have not data to support my thinking other than what I have tried so far. I would like to hear others experience as well as any suggestions to address my current dilemma. Good Luck. Chucking is usually caused by too little pin weight ... the pin should be AT LEAST 20% of the total 5th wheel weight. Both the hitch and pin box you referenced are both premium products and either one, by itself, should greatly reduce chucking. Something else must be going on with your rig. Harshness is very subjective, so "bad" for one might be "acceptable" for another. How does your truck ride when not towing? When you hook up your 5th wheel, does the truck sag? If so (with no air bags) to level it out, you will have used up however many inches of rear suspension travel that you sag. This can cause the truck to hit the suspension rubber stops, which is very harsh. Other than these thoughts, I don't know what else you might try to make you experience better. Link to comment Share on other sites More sharing options...
Hunter11 Posted September 23, 2016 Report Share Posted September 23, 2016 For an alternative. Has a B&W adapter.http://www.comfortri..._model_245.html I have this hitch and have for about 4 years. Works great and I don't have to deal with airbags. Link to comment Share on other sites More sharing options...
Ronbo Posted September 23, 2016 Report Share Posted September 23, 2016 If you are 85-90 lbs in your trailer saver hitch, you have no benefit of an air hitch. This is why I went to the ET Jr. Great replacement and never looked back. When my DW saw Henry pull into the rally and saw how his hitch just floated, she did not balk at the price. Link to comment Share on other sites More sharing options...
