Brad NSW Posted July 15, 2018 Report Share Posted July 15, 2018 I bought a new TPMS. Attached video shows how the alarm notifies you of low tire pressure. TPMS video I TOOK THE VIDEO LINK DOWN. Owner called and asked if I would. He's going to give a full refund. Seems like a nice guy but not sure he really knows how the TST works and what's needed to monitor tires when driving a semi that can't feel anything the trailer is doing.... For those with TPMS, doesn't the alarm come on and stay on when you go below the low set point your program? This one alarms for 3 seconds, then the LP alarm goes away and you have no indication of a flat until the next time it cycles. At the end of the video, the tire is at zero PSI and I got a long (5-7 second) alarm and then it disappears completely/indefinitely...until one of the other tires change pressure or temp, which could be a LONG time. Does this make sense to you? If I remember correctly, my old Pressure Pro had an alarm that wouldn't go off until you cleared it. In other words, you had a constant visual/audio alarm. If you were distracted for a few seconds, you wouldn't miss the alarm. Feedback appreciated. 2010 Freightliner, DD15 Eaton Ultrashift, 2015 New Horizons 5th Wheel. Occupants - Dena/Brad/Hershey BLOG LINK Link to comment Share on other sites More sharing options...
Dutch_12078 Posted July 15, 2018 Report Share Posted July 15, 2018 Our TST 507 TPMS alarms at low/high pressures and high temps by sounding the alarm continuously as soon as the condition is detected, flashing a red LED, and blinking the offending tire position on the display. Tapping any of the control buttons will silence the alarm, but the flashing and blinking continue until the issue is resolved or the system is turned off. The sensors transmit to the monitor much more often than the display sequences, and an alarm condition switched to the offending position almost instantly. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
SuiteSuccess Posted July 15, 2018 Report Share Posted July 15, 2018 55 minutes ago, Dutch_12078 said: Our TST 507 TPMS alarms at low/high pressures and high temps by sounding the alarm continuously as soon as the condition is detected, flashing a red LED, and blinking the offending tire position on the display. Tapping any of the control buttons will silence the alarm, but the flashing and blinking continue until the issue is resolved or the system is turned off. The sensors transmit to the monitor much more often than the display sequences, and an alarm condition switched to the offending position almost instantly. X2 with our TST. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted July 15, 2018 Report Share Posted July 15, 2018 X3 with my TST. Roger Link to comment Share on other sites More sharing options...
Brad NSW Posted July 15, 2018 Author Report Share Posted July 15, 2018 I'm in conversation with the manufacturer and sent him the video. He swears his does the same thing as the TST but it doesn't. All indications of LP go away for long periods. With cab noise and distractions of driving, that's UNSAT in my book. He's offered to refund my money but I really want him to understand that his system has a design flaw that give people a false sense of security. 2010 Freightliner, DD15 Eaton Ultrashift, 2015 New Horizons 5th Wheel. Occupants - Dena/Brad/Hershey BLOG LINK Link to comment Share on other sites More sharing options...
SuiteSuccess Posted July 15, 2018 Report Share Posted July 15, 2018 Brad, Honestly, get the refund and go with a known system. You’ll be better off. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
offroad Posted July 15, 2018 Report Share Posted July 15, 2018 4 hours ago, Brad NSW said: I'm in conversation with the manufacturer and sent him the video. He swears his does the same thing as the TST but it doesn't. All indications of LP go away for long periods. With cab noise and distractions of driving, that's UNSAT in my book. He's offered to refund my money but I really want him to understand that his system has a design flaw that give people a false sense of security. really think thee are not manufacturers but instead reseller importers. They have a suite of products that they bought from china, and are selling them, without testing Link to comment Share on other sites More sharing options...
HERO Maker Posted July 16, 2018 Report Share Posted July 16, 2018 Maybe someday I'll go to the TST system, but right now staying with Pressure Pro. But I'm with Carl on this one..... get your money back and go to a known system. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Brad NSW Posted July 16, 2018 Author Report Share Posted July 16, 2018 Got it and will go with TST or Pressure Pro. Amazon Prime Day tomorrow😀! Will probably go back to the TST system I used with my Dodge. Saved my bacon once, going through LA...slow leak on the 5th wheel.. 2010 Freightliner, DD15 Eaton Ultrashift, 2015 New Horizons 5th Wheel. Occupants - Dena/Brad/Hershey BLOG LINK Link to comment Share on other sites More sharing options...
