need a little help
jimd40
i weighed my 2018 aspect today and front axle 4460   drive axle 9360  gross  13820      it is loaded with full water and propane  and golf clubs     the door tag says  gvwr 14500  f 5000  and rear 9600  now my question  how much can i tow ?? I'm get old because i can't remember stuff thanks   jim
If it has the triton v10, and just the standard hitch then it's 5k. But you'll also have to consider hitch weight into your GVWR, rear axle rating and and stay under your GCWR (gross combined weight rating).
You should have quite a lot of flexibility.
18 minutes ago, jimd40 said:
yes it ford v10  an and hitch says 5000 lbs  wanted to know what weigh limits i have thanks
Well.. your GCWR is likely something in the 40k range, but that's kind of moot since it has a fairly light hitch on the Aspect and your rear axle ratings will be the limiting factor... which is why it has a fairly light hitch on it. You don't have a lot left to play with when the chassis is confiured as a class C. Not because your rig is not capable of actually pulling it but because your axles and chassis are not capable of supporting much additional weight.
If you plan on towing a trailer of some sort, that's likely going to add more to your axle weight (in the form of tongue weight) than pulling a small toad 4 down so it's difficult to say exactly what a tow weight capacity would be.
You can likely have quite a large toad (4-down), but then you also need to take into account sway factors and what is actually "safe" to pull as a toad. Generally speaking though... if a toad is in your plans... just about any moderately sized vehicle will be a "GO" for you.
Find the Gross Combined Weight Rating (GCWR) of your RV and subtract your gross weight (13820) from that number.  This is the maximum weight your RV can tow.  This doesn’t mean your RV can actually tow that much weight because it might be limited by some other factor (like rear axle rating, hitch capacity, etc), but it will give you the best case scenario max tow weight.
My First Solar Install Thread
I visited the Winnebago Aspect website to check the weight ratings they show.  This is what it shows:
Gross Combined Weight Rating    22,000
Gross Vehicle Weight Rating         14,500
Trailer Hitch 5,000-lb. drawbar/350-lb. maximum vertical tongue weight
