Wrknrvr Posted May 17, 2023 Report Share Posted May 17, 2023 Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted May 17, 2023 Author Report Share Posted May 17, 2023 One clue is it prevents sparks. Keeps you blood pressure normal. It also contains bad words from escaping your mouth. I might be a little board working on our truck. Quote Link to comment Share on other sites More sharing options...
HERO Maker Posted May 17, 2023 Report Share Posted May 17, 2023 Yes you are! But your mind is still cranking! Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Wrknrvr Posted May 17, 2023 Author Report Share Posted May 17, 2023 (edited) I got to use the tool of the week, just 45 minutes ago. Yep I did. That tool is used to put over the starter to control sparks. Since I do not have a starter issue, and I did not want to disconnect the batteries. But by putting that tool over top of the starter, it protects the wrench you dropped from creating sparks, bad words from falling out of your mouth and more work. I do not need that. Last Friday I drop a wrench down by the starter. Yep, that will raise the blood pressure. Now if it made a certain connection with a hot wire, should I grab it and try to remove it. Or what. Edited May 17, 2023 by Wrknrvr Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 17, 2023 Report Share Posted May 17, 2023 I would have bet it was used in the rolled up position,as pictured. As a head rest under the truck, while avoiding the Honey-do list. Don't want to get rocks stuck in the back of your head, from napping too long and hard. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
