speedbugy Posted January 5, 2023 Report Share Posted January 5, 2023 Trying to find a easier way to winterize when leaving for a few days or weeks I think I found it. I added a T to the anode rod hole with a spigot to drain the hot water heater and extended the low point drains. Now even my wife can do it. Quote Link to comment Share on other sites More sharing options...
ARGO Posted January 7, 2023 Report Share Posted January 7, 2023 Can't see pipe joints- but if you put teflon tape on the threads you may have negated the anode rod. Check continuity. Quote You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
lappir Posted January 7, 2023 Report Share Posted January 7, 2023 50 minutes ago, ARGO said: Can't see pipe joints- but if you put teflon tape on the threads you may have negated the anode rod. Check continuity. Is that really a thing? I have always added Teflon tape and still see where the rod seems to be doing it's job. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
DJohns Posted January 7, 2023 Report Share Posted January 7, 2023 If no pipe dope or teflon tape is used on the tee there will be leaks. The threads will cut thru the tape anyway. Quote 2002 Beaver Marquis Emerald C-12 Cat 505 HP 2014 Volvo 630 D-13 I Shift SOLD 2017 New Horizons SOLD Link to comment Share on other sites More sharing options...
Ray,IN Posted January 8, 2023 Report Share Posted January 8, 2023 On 1/7/2023 at 10:32 AM, DJohns said: If no pipe dope or teflon tape is used on the tee there will be leaks. The threads will cut thru the tape anyway. That depends entirely on the person turning the wrench, Teflon tape is designed to reduce torque required to stop a joint from leaking, but if the joint is over-tightened you are right. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
