bags Posted August 20, 2022 Report Share Posted August 20, 2022 Good afternoon I am finally going to add a hitch camera to my truck. I remember seeing one that was dead simple and removable. It was made out of 1/2 pipe and a magnet or two. Before I reinvent the wheel does anyone have a photo of one that they like? Thanks in advance. JB Quote John and Michal Bagley 1999 Volvo 610 the 'Millennium Falcon', 400 hp ISM, Autoshift Gen 2, single axel w/steel bed, Pressure Pro, VMSPC, Trailer Saver Air Hitch, 3 bags, 38 foot Royals International, and our 3 dogs. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 21, 2022 Report Share Posted August 21, 2022 (edited) You may have to enlarge but this is mine. Heavy duty magnet base from Harbor Freight and short length of pipe. Have used this setup for 13 years with no issues. Magnet is plenty strong. https://www.harborfreight.com/66mm-round-magnet-96650.html On edit this was my original bolted plate which I didn’t like so I changed to the magnet base. Edited August 21, 2022 by SuiteSuccess Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
bags Posted September 2, 2022 Author Report Share Posted September 2, 2022 Thank you ever so much. JB Quote John and Michal Bagley 1999 Volvo 610 the 'Millennium Falcon', 400 hp ISM, Autoshift Gen 2, single axel w/steel bed, Pressure Pro, VMSPC, Trailer Saver Air Hitch, 3 bags, 38 foot Royals International, and our 3 dogs. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted September 3, 2022 Report Share Posted September 3, 2022 19 hours ago, bags said: Thank you ever so much. JB 👍 Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
trimster Posted September 8, 2022 Report Share Posted September 8, 2022 I did the same thing. HF magnets. I used 3/8" threaded rod as the vertical support. I tried one magnet. Not enough. Used some angle steel to make a base. Put 2 magnets on that. It stays where put. I also left enough slack in the cable to the camera so I can move it to the end of the bed and look down if I have to do a ball mount tow. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
bags Posted September 9, 2022 Author Report Share Posted September 9, 2022 Thanks. Good idea. JB Quote John and Michal Bagley 1999 Volvo 610 the 'Millennium Falcon', 400 hp ISM, Autoshift Gen 2, single axel w/steel bed, Pressure Pro, VMSPC, Trailer Saver Air Hitch, 3 bags, 38 foot Royals International, and our 3 dogs. Link to comment Share on other sites More sharing options...
Sculptor Posted September 26, 2022 Report Share Posted September 26, 2022 My first version was also HF magnets, specifically the tool bar magnets not the round. I mounted a light cross of aluminum and the camera mounted on the crossmember. This was stuck on the centerline of the ET hitch front panel. Later I bought a second identical magnet. The first magnet tended to slip sideways a little, so I placed the second magnet on the ET hitch front panel alongside the first magnet bar. It “worked” but tended to vibrate the picture underway. Last year I changed all that out for a galvanized pipe and mounted it to the ET hitch with U-bolts. The picture is stable now. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
