Bill w/bus Posted April 1, 2021 Report Share Posted April 1, 2021 After 10 years of service the bathroom fantastic vent thermostat has failed. And better yet it is defined as an obsolete part. Any thoughts suggestions on how to proceed? Thanks, Bill Quote Bill & Lynn Baxter MCI102A3 Conversion, Detroit Diesel S50 Link to comment Share on other sites More sharing options...
Lou Schneider Posted April 1, 2021 Report Share Posted April 1, 2021 Jumper the thermostat contacts and turn the fan on and off manually. Or add an external thermostat in the 12 volt supply line. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted April 1, 2021 Report Share Posted April 1, 2021 Polish the contacts with 1000 grit sand paper. Test and report back. Vern in a T-shirt Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted April 2, 2021 Report Share Posted April 2, 2021 (edited) Just a very simple bi-metal RV furnace thermostat will work. It does not require a power source. I replaces one of mine and it works fine, only difference is the tiny lever works backwards to the OEM 'stat and it's about 1/2 the size. It has the off/on lever on the bottom. It's available with a rotary dial too, just run a search. Yes, Fantastic Fan was bought by Dometic/Thetford, lifetime warranty on lid is still valid, as is quality according to those who have replaced the motor since the buyout. Edited June 14, 2022 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted April 2, 2021 Report Share Posted April 2, 2021 I realize replacing the vent is probably anathema, but that is what I did with the kitchen fan. It took about three hours to take out the old one and put in the new. Wayne & Jinx 2017 F-350 diesel, dually 2006 Carriage Carri-Lite 36KSQ Quote Jinx and Wayne 2006 Carriage Carri-Lite 36KSQ Link to comment Share on other sites More sharing options...
Bramblehollow Posted June 13, 2022 Report Share Posted June 13, 2022 How do you wire the RV furnace Thermostat to work in reverse (ie to turn the fan on when the temp hits 78, instead of turning it off) Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted June 14, 2022 Report Share Posted June 14, 2022 (edited) 23 hours ago, Bramblehollow said: How do you wire the RV furnace Thermostat to work in reverse (ie to turn the fan on when the temp hits 78, instead of turning it off) Look at your OEM "stat, compare to that picture. That "stat pictured only has one off position - on the left. When I push the lever to 70 it will not power the fan if indoor temp. is under 70., when indoor temp goes over 70 it turns on the fan. 12V wire to fan is moved to other side of the new 'stat terminals best I remember. Edited June 14, 2022 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
