chisum 57 Posted January 28, 2021 Report Share Posted January 28, 2021 Takes 15 - 20 minutes to fill 55 gal gas tank ? Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 28, 2021 Report Share Posted January 28, 2021 Hose knocked somewhere, either fill or vent. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted January 28, 2021 Report Share Posted January 28, 2021 Is this at every station or just a single fill? I've found a couple of stations that pump very slowly. I know it wasn't a problem with my tank because it is a truck bed auxiliary tank. Wayne & Jinx 2017 F-350 diesel, dually 2006 Carriage Carri-Lite 36KSQ Quote Jinx and Wayne 2006 Carriage Carri-Lite 36KSQ Link to comment Share on other sites More sharing options...
Kirk W Posted January 28, 2021 Report Share Posted January 28, 2021 You don't say what RV you have but this has been a problem before, usually caused by the routing of the vent line from the fuel tank. If the line has a loop or a U in it then the low point can collect liquid and block the air from venting out and so require the fill to be very slow as air has to blow back out the fill tube. You might be able to use compressed air in the vent line to blow back through it as a temporary fix, but if it works the problem will likely return after a while. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
oldjohnt Posted January 28, 2021 Report Share Posted January 28, 2021 Ive owned a ton of Class C's over the past 49 years of RVing and seldom experienced that problem. My best guesses of the cause not being there are a kinked or too sharp bent or somehow otherwise restricted fill hose or else a kinked or clogged or improperly routed or collapsed vent hose. Take a good look at both and insure there are no over sharp bends or kinks or any collapsed hoses?? John T Live from the RV near Avon Park Florida nice n warmmmmmmmmmmm Quote Link to comment Share on other sites More sharing options...
