Wrknrvr Posted October 29, 2020 Report Share Posted October 29, 2020 (edited) So we have had two nights at about 0 degrees. I did remove the waterline and used tank water. I have a commercial heat tape on the waterline with foam insulation on top of it. When I bout 6” plastic ductwork for my underbelly furnace install I hade extra 6” ductwork. So i installed it over top of the waterline for two reasons. More insulation and just in case we needed to travel. I could just pull it out if the 6” is frozen in place.. Now I did try to seal the end so as to stop water infiltrating the fiberglass. Vern in a T-shirt Edited October 29, 2020 by Wrknrvr Quote Link to comment Share on other sites More sharing options...
noteven Posted October 30, 2020 Report Share Posted October 30, 2020 Looking good Vern... A Canada method is to affix a heat tape straight down the hose - don't spiral it around the hose. Then wrap with aluminum duck sealing tape or heavy aluminum foil to conduct the heat all around the hose. Then insulate with your preferred insulation such as bubble wrap, closed cell foam, batt insulation (if it cannot get wet) Don't let the Winter Winds get at it anywhere.... Wet fiberglass has not much insulation values. Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 30, 2020 Report Share Posted October 30, 2020 When buying heat trace, specify "Self-regulating" vs unregulated. Way better life span, way more robust. An indicator light can also be installed on the end opposite the power supply, to indicate failures. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
