Grunt1975 Posted October 11, 2020 Report Share Posted October 11, 2020 When it rains I get rain in drops through the air vents. We replaced the gasket under the rear air conditioner but still get the drops. Any suggestions? Quote Link to comment Share on other sites More sharing options...
rpsinc Posted October 11, 2020 Report Share Posted October 11, 2020 So are your talking about vents or AC penetrations? Not understanding. Quote Marcel Link to comment Share on other sites More sharing options...
Ray,IN Posted October 11, 2020 Report Share Posted October 11, 2020 It will help if we know the answer to rpsinc's questions and make and year of RV. For instance, some older RV's roof can sag where the air conditioner is mounted, which allows water to pool around the gasket and leak into the RV. The gasket is only compressed 1/2 its thickness, more or less can allow a leak. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Wrknrvr Posted October 15, 2020 Report Share Posted October 15, 2020 Those drops may be coming from other entrance points. Just coming out of those vents. Last winter I had a similar problem that a customer called me about. I looked all over the roof with the customer and would not find anything wrong. So I checked the tightness on the ac units. They were just a tad loose. There was a junction box on the roof for solar. I opened it up and noticed the o ring style seal was not installed correctly. Cleaned it up and where it fit in. Used some pure silicone dielectric grease on it. So the next rain day in Arizona where we were, he called and said it is still leaking. But only in one spot. Then he moved across the street from us. Looked at the roof very seriously and still could not find anything wrong. Apparently it finally dried out. No more leeks. And I have seen that situation happen before. Just my thoughts, Vern in a T-shirt Quote Link to comment Share on other sites More sharing options...
