woman_who_sees Posted August 29, 2020 Report Share Posted August 29, 2020 Does anyone know how to remove water stains from the ceiling? Jan Quote Bill (DH), Jan (DW), Sunshine (DBird), and Gila and Tacobelle (DCats) 2004 Winnebago Sightseer "Folks are about as happy as they make up their minds to be" (after a cup of coffee) Link to comment Share on other sites More sharing options...
Kirk W Posted August 29, 2020 Report Share Posted August 29, 2020 To some degree, it depends on where the stains came from. If caused by an external leak they are more difficult than if from something sprayed on it from the inside. Another significant factor is the material your ceiling is made of. For a surface stain we found an upholstery cleaner worked, fairly well. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
NDBirdman Posted August 29, 2020 Report Share Posted August 29, 2020 A good stain covering primer then paint, after the stain/water source is repaired/replaced. Quote 2022 Coachman Leprechaun, traveling around to dark sky areas and chasing the stars. Link to comment Share on other sites More sharing options...
mptjelgin Posted August 29, 2020 Report Share Posted August 29, 2020 If it is a fabric-covered ceiling, the "Oxi" type products can work well on a water stain. Test in an inconspicuous area first to make sure it doesn't do something you don't like. Quote Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
Ray,IN Posted August 29, 2020 Report Share Posted August 29, 2020 A member tipped me off to using Folex carpet cleaner, it works great! Due to an air leak, the ceiling was stained with diesel exhaust, black and oily. The Folex removed everything and returned the ceiling carpet to white again. Then used in on an old water leak stain, it is gone too. We tried using carpet paint, ugh. Not only did it make the ceiling carpet hard and stiff, it is now crumbling off. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
