lappir Posted January 28, 2017 Report Share Posted January 28, 2017 I have the Coleman Mach in the "possum belly" of my Spacecraft trailer. It's a little cool in North Florida this morning. I keep my inside temperatures maybe a little lower than most, but have learned I need to have the "Heat Pump" running some to decrease the inside humidity and decrease the condensation I have on some of the metal that extends from the outside of the trailer to the inside. I didn't consider the effects of where the HVAC unit was mounted during the build. I have learned in the past few years that it actually does make a significant difference on where it's mounted and where the supply and return runs are located. My supply to the center ceiling vents in the Spacecraft come up an exterior wall. There is a bit of insulation over the run, but I am not sure just how much. I do know if my trailer is facing North and South and the afternoon sun is striking the same side, my A/C runs a lot more than if I would turn the trailer around. It takes time to push out the hot air and start getting cool air. The reverse is true when it's cooler and may be more noticeable to some. Having the supply along an interior wall would be much better. The return going to the exterior would effect the efficiency much less I believe. The first room for the vent of the supply is in my bathroom. I can close the door and make it really cool or really warm, but it leaves the rest of the trailer with steadily increasing or decreasing temperatures at each end of the trailer. If it's really hot or cold I do close the vents in my garage space and close the door between the garage and living space. If I ever have to replace my HVAC unit I will request that change with the new instillation. These are my personal opinions and I have no science or actual build experience, what I think may work, may not be any better. Consider accordingly. Rod Link to comment Share on other sites More sharing options...
sandsys Posted January 28, 2017 Report Share Posted January 28, 2017 The best thing about the basement air we had in our previous Class A was the ability to hold a conversation while it was running. None of our roof air options allowed that. Just one more thing to consider. Linda Sand Link to comment Share on other sites More sharing options...
Pat & Pete Posted January 28, 2017 Report Share Posted January 28, 2017 The best thing about the basement air we had in our previous Class A was the ability to hold a conversation while it was running. None of our roof air options allowed that. Just one more thing to consider. Linda Sand We have what I believe to be OEM DuoTherm , 13.5 BTU AC units ( 2 ) , perched atop our class A 2000 Monaco Monarch 34PBD . They are a bit louder running than not , but not nearly loud enough to halt any conversation . Note that we only run one at a time . Both at once would freeze us . Maybe you simply had the misfortune to have had inferior units ? I know some are not built with quiet in their design , but ... Link to comment Share on other sites More sharing options...
MrSeas Posted January 28, 2017 Report Share Posted January 28, 2017 Any chance you folks that have "quiet" units sharing with the rest of us what A/C unit you have and in what in type of rig set up? Might be more helpful than just saying mine is "different" than yours! Link to comment Share on other sites More sharing options...
wildmandmc Posted January 29, 2017 Report Share Posted January 29, 2017 I have a Basement AC Unit. About a year ago i had to have it replaced. One Compressor went bad. I have never owned a Unit with Top AC, But i have been In a Few. The First Duct is in Bedroom. I have to shut one off during Summer as it gets too cold. The Drain is of course under unit (outside). In the future i maybe trading it in. Hopefully to get one with basement ac . Link to comment Share on other sites More sharing options...
Pat & Pete Posted January 29, 2017 Report Share Posted January 29, 2017 Any chance you folks that have "quiet" units sharing with the rest of us what A/C unit you have and in what in type of rig set up? Might be more helpful than just saying mine is "different" than yours! Of course . I edited my above post . Link to comment Share on other sites More sharing options...
wildmandmc Posted January 30, 2017 Report Share Posted January 30, 2017 For Sound, mine seems a lot quieter than my friends Monoco with 3 Roof Top Units. Both of us have 2000 year models. Link to comment Share on other sites More sharing options...
Oldelevman Posted February 1, 2017 Report Share Posted February 1, 2017 I would say don't consider it but that's my opinion. We had a 2004 Itasca Horizon for 11 years and we had nothing but trouble with it. We went thru a couple compressors and had the main line from the unit that runs up the rear cap redone because it had ruptured and was cooling the engine and not the inside. It never would get cold enough to our liking. We finally ended up buying a stand alone ac from Lowes's and venting it out a window next to the kitchen when we were parked and that helped. Poor design. Don't know if anyone still uses it in new RV's anymore. Link to comment Share on other sites More sharing options...
wildmandmc Posted February 1, 2017 Report Share Posted February 1, 2017 They Stopped it sometime around 2010./2011. That's probably the Biggest Drawback. when unit gets old. Duct work on them. Only prob i had with it was the elbow coming out of unit. Link to comment Share on other sites More sharing options...
